VTech Write and Learn Creative Center Slider Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
14
Past 30 Days:
94
All Time:
916
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Introduction
Go to step 1 ↓
The slider is an important aspect for the VTech Write and Learn Creative Center because the slider allows the children to continue to learn by erasing previous work. The following repair guide addresses properly replacing the slider.
Tools
    1. VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 1 of 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 2 of 3 VTech Write and Learn Creative Center Slider Replacement, Back Panel: step 1, image 3 of 3
      • Remove all eleven 9mm PH 2 Phillips screws securing the back of the case.
      Ask FixBot
    1. VTech Write and Learn Creative Center Slider Replacement, Slider: step 2, image 1 of 1
      • Remove the two 7mm PH 0 Phillips screws holding the slider to the slider handle.
      • The back of the slider will likely be coated in lubricant. Be careful not to make a mess.
      Ask FixBot
Philip Zietkowski
345 Reputation
2 Guides authored
1 Guide Comment
This helps me alot. I haven't took my son's apart yet but my question is when you turn the slider to erase the board it will not erase. Do you think I will need to reattach something or is this fixable if take it apart? My email is caitlinmanderson0@gmail.com if you could kindly email me with any tips.
caitlin28901 - Reply Share
Past 24 Hours: 4
Past 7 Days: 14
Past 30 Days: 94
All Time: 916
