VTech VM3254 Monitor Speaker Replacement
    1. VTech VM3254 Monitor Speaker Replacement, Battery: step 1, image 1 of 2 VTech VM3254 Monitor Speaker Replacement, Battery: step 1, image 2 of 2
      • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
      Ask FixBot
    2. VTech VM3254 Monitor Speaker Replacement: step 2, image 1 of 3 VTech VM3254 Monitor Speaker Replacement: step 2, image 2 of 3 VTech VM3254 Monitor Speaker Replacement: step 2, image 3 of 3
      • Use the iFixit Jimmy tool to begin removing the face of the monitor.
      • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
      • Once the screen has been separated, lift it from the case.
      • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
      Ask FixBot
    3. VTech VM3254 Monitor Speaker Replacement: step 3, image 1 of 2 VTech VM3254 Monitor Speaker Replacement: step 3, image 2 of 2
      • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
      • Remove the bracket.
      Ask FixBot
    4. VTech VM3254 Monitor Speaker Replacement: step 4, image 1 of 3 VTech VM3254 Monitor Speaker Replacement: step 4, image 2 of 3 VTech VM3254 Monitor Speaker Replacement: step 4, image 3 of 3
      • Gently remove the battery from its location.
      • Carefully disconnect the bundled cable connector from the circuit board.
      Ask FixBot
    1. VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: step 5, image 1 of 2 VTech VM3254 Monitor Speaker Replacement, Monitor Speaker: step 5, image 2 of 2
      • Remove the two 7 mm Phillips #00 screws from the speaker.
      • Carefully remove the speaker and its cords from the motherboard.
      • Handle gently to not break the motherboard or any other parts.
      Ask FixBot
    2. VTech VM3254 Monitor Speaker Replacement: step 6, image 1 of 1
      • Desolder the wire connecting the speaker to the board.
      Ask FixBot
Travis Gunter
135 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 12
Past 30 Days: 41
All Time: 830
