VTech VM3254 Monitor Circuit Board and Screen Replacement
    1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: step 1, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Battery: step 1, image 2 of 2
      • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
      Ask FixBot
    2. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 1 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 2 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 2, image 3 of 3
      • Use the iFixit Jimmy tool to begin removing the face of the monitor.
      • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
      • Once the screen has been separated, lift it from the case.
      • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
      Ask FixBot
    3. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 3, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 3, image 2 of 2
      • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
      • Remove the bracket.
      Ask FixBot
    4. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 1 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 2 of 3 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 4, image 3 of 3
      • Gently remove the battery from its location.
      • Carefully disconnect the bundled cable connector from the circuit board.
      Ask FixBot
    1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: step 5, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Speaker: step 5, image 2 of 2
      • Remove the two 7 mm Phillips #00 screws from the speaker.
      • Carefully remove the speaker and its cords from the motherboard.
      • Handle gently to not break the motherboard or any other parts.
      Ask FixBot
    2. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 6, image 1 of 1
      • Desolder the wire connecting the speaker to the board.
      Ask FixBot
    1. VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: step 7, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement, Monitor Circuit Board and Screen: step 7, image 2 of 2
      • Remove the three 8 mm Phillips #00 screws.
      • Gently remove the screen and circuit board from the case.
      Ask FixBot
    2. VTech VM3254 Monitor Circuit Board and Screen Replacement: step 8, image 1 of 2 VTech VM3254 Monitor Circuit Board and Screen Replacement: step 8, image 2 of 2
      • Remove the button assembly from the front of the screen unit.
      • Flip the screen unit back over and desolder the wire holding it to the case.
      Ask FixBot
Christina Block
375 Reputation
4 Guides authored
2 Guide Comments
Any source for replacement screens?
Rob O - Reply Share
Would their be a way to connect the monitor to say a HDMI or VGA cable. To connect to a computer so you could get the video on your computer monitor and possibly be able to record to a hard drive. Just a thought I had. Thank you
Nad Bauch - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 83
All Time: 2,151
