Up to 20% off select tools
VTech VM3254 Battery Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
3
Past 7 Days:
34
Past 30 Days:
139
All Time:
3,406
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
If the VTech VM3245 will not switch on, the battery may need to be replaced. The information below specifically states how to remove the battery and replace it with a new one. The only tools needed include a Phillips #00 screwdriver, Jimmy, and one opening pick. You will not have any difficult steps, but remove the front cover of the device attentively.
    1. VTech VM3254 Battery Replacement, Battery: step 1, image 1 of 2 VTech VM3254 Battery Replacement, Battery: step 1, image 2 of 2
      • Turn the monitor on its back, and remove the two 8 mm Phillips #0 case screws.
      Ask FixBot
    2. VTech VM3254 Battery Replacement: step 2, image 1 of 3 VTech VM3254 Battery Replacement: step 2, image 2 of 3 VTech VM3254 Battery Replacement: step 2, image 3 of 3
      • Use the iFixit Jimmy tool to begin removing the face of the monitor.
      • You may need to use an opening pick to hold the screen open as you move the Jimmy tool around all the edges of the device.
      • Once the screen has been separated, lift it from the case.
      • Be gentle while removing the screen. There are wires connected to the two pieces that may be damaged.
      Ask FixBot
    3. VTech VM3254 Battery Replacement: step 3, image 1 of 2 VTech VM3254 Battery Replacement: step 3, image 2 of 2
      • Remove the four 8 mm Phillips #00 screws from the bracket that secures the battery.
      • Remove the bracket.
      Ask FixBot
    4. VTech VM3254 Battery Replacement: step 4, image 1 of 3 VTech VM3254 Battery Replacement: step 4, image 2 of 3 VTech VM3254 Battery Replacement: step 4, image 3 of 3
      • Gently remove the battery from its location.
      • Carefully disconnect the bundled cable connector from the circuit board.
      Ask FixBot
Author
with
Jackson Meacham
109 Reputation
1 Guide authored
1 Guide Comment
What is the battery that needs to be replaced called?
Aden Brooks - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 139
All Time: 3,406
