VTech Safe and Sound DM111-2 Battery Replacement
Views: 6.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
93
All Time:
6,061
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 seconds
Difficulty: Very easy
Introduction
Go to step 1 ↓
Use this guide to replace the battery if the device shuts off during use or will not turn on. Be careful while removing the battery, make sure to check for signs of corrosion or battery acid. once the batteries have been removed make sure to replace them with alkaline batteries.
    1. VTech Safe and Sound DM111-2 Battery Replacement, Battery: step 1, image 1 of 1
      • Expose the battery compartment by removing the lower back cover of the device.
      • Do this by holding the back side of the device upside down in your hands and applying pressure to the indented portion with both thumbs.
      Ask FixBot
    2. VTech Safe and Sound DM111-2 Battery Replacement: step 2, image 1 of 1
      • Once the batteries are exposed, use your index finger to push the battery against the spring and pull up to dislodge the battery.
      • Make sure to check for battery acid or other corrosive substances before touching the battery. If needed, use latex gloves to avoid skin irritation from battery acid.
      Ask FixBot
Darrell Griffin
222 Reputation
2 Guides authored
USF Tampa, Team 6-3, Remmell Fall 2015 Member of USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 93
All Time: 6,061
