VTech Safe and Sound DM111-2 Baby Unit Motherboard replacement Guide
Views: 1.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
81
All Time:
1,517
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
You will need knowledge of how to use a soldering iron. For more information regarding soldering visit: Soldering Skills
Used for mother board replacement and repair If the unit starts behaving erratically. Along the process you will determine if the behavior is not due to a faulty power jack, wires, and or microphone. If so proceed with motherboard replacement.
Tools
    1. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Baby Unit Motherboard replacement Guide: step 1, image 1 of 1
      • Along the back of unit there are two 4mm philips head screws towards the bottom of the unit. Start by removing these two screws using your PH0 screwdriver.
      Ask FixBot
    2. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 2, image 1 of 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 2, image 2 of 2
      • Using the plastic spudger gently pry along the middle of the 2 sections of the plastic housing in order to release plastic latches on the inside of the housing.
      • Unlike the parent unit there are no wires across the two housing pieces, so once the latches are undone simply pull it apart without worry of disconnecting anything.
      Ask FixBot
    3. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 3, image 1 of 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 3, image 2 of 2
      • Once apart the motherboard will be exposed with two 4mm phillips head screws near the top and 4 wires leading leading to a circuit board hidden under the motherboard.
      • Remove the two screws near the top of the motherboard.
      Ask FixBot
    4. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: step 4, image 1 of 2 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide, Disconnect the microphone: step 4, image 2 of 2
      • Remove the strip of adhesive tape located under the motherboard.
      • Gently lift the motherboard to expose the inner components.
      • Use a spudger to scrape away the adhesive and foam connecting the microphone.
      • Unscrew the 4mm phillips head screw holding the microphone in place.
      Ask FixBot
    5. VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 5, image 1 of 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 5, image 2 of 3 VTech Safe and Sound DM111-2  Baby Unit Motherboard replacement Guide: step 5, image 3 of 3
      Tool used on this step:
      Desoldering Pump
      $3.99
      Buy
      • Before de-soldering, check to see no scorching or broken connections appear on the wires, power supply jack or antenna.
      • De-solder the connections from the motherboard using a soldering iron and a solder sucker.
      • De-solder the connections to the microphone, located on the bottom left of the mother board.
      • De-solder the 4 wires connecting the LED board to the motherboard.
      • De-solder the antenna's solder joint, located above the microphone wire connection.
      Ask FixBot
Jean Carlos
201 Reputation
2 Guides authored
USF Tampa, Team 6-3, Remmell Fall 2015 Member of USF Tampa, Team 6-3, Remmell Fall 2015
USFT-REMMELL-F15S6G3
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 81
All Time: 1,517
