VTech Safe And Sound DM221 Speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
70
All Time:
747
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Introduction
Go to step 1 ↓
Follow this repair guide to find out how to replace the speaker with a functional one.
Tools
    1. VTech Safe And Sound DM221 Speaker Replacement, Speaker: step 1, image 1 of 1
      • Remove the battery cover.
      Ask FixBot
    2. VTech Safe And Sound DM221 Speaker Replacement: step 2, image 1 of 1
      • Unplug the battery from its connector and remove.
      Ask FixBot
    3. VTech Safe And Sound DM221 Speaker Replacement: step 3, image 1 of 1
      • Using the Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws at the bottom of the monitor.
      Ask FixBot
    4. VTech Safe And Sound DM221 Speaker Replacement: step 4, image 1 of 1
      • Separate the back half of the device from the front using the metal spudger.
      Ask FixBot
    5. VTech Safe And Sound DM221 Speaker Replacement: step 5, image 1 of 1
      • Remove the two 5.0 mm Phillips #00 screws at the top of the device which holds the antenna at the top of the motherboard.
      • This will allow the removal of the silver handle.
      Ask FixBot
    6. VTech Safe And Sound DM221 Speaker Replacement: step 6, image 1 of 1
      • Remove the “TALK” button to get access to remove the motherboard.
      Ask FixBot
    7. VTech Safe And Sound DM221 Speaker Replacement: step 7, image 1 of 1
      • Push down on the antenna, located on the top of the motherboard.
      Ask FixBot
    8. VTech Safe And Sound DM221 Speaker Replacement: step 8, image 1 of 1
      • Gently remove the motherboard away from the monitor.
      • Be careful not to disconnect the red wire.
      Ask FixBot
    9. VTech Safe And Sound DM221 Speaker Replacement: step 9, image 1 of 1
      • Use the plastic spudger to push the two white plastic tabs, at the bottom of the device, up to release the metal retaining clip.
      Ask FixBot
Krystal
600 Reputation
5 Guides authored
USF Tampa, Team 1-5, Leahy Fall 2015 Member of USF Tampa, Team 1-5, Leahy Fall 2015
USFT-LEAHY-F15S1G5
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 70
All Time: 747
