Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Introduction
Go to step 1 ↓Is your antenna not picking up the monitor signal? Read this repair guide to find out how to replace your antenna.
Tools
Spudger4.9
Remove the battery cover by sliding it down.
Firmly grasp the battery and pull to disconnect the battery from its connector.
Using a Phillips #00 screwdriver, unscrew the two 5.0 mm Phillips #00 screws located at the bottom of the monitor inside of the device.
1 Guide Comment
Great tutorial thanks! What type of antenna should I replace it with to get better reception?
