Up to 20% off select tools
VTech MobiGo Touch Learning System Screen Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
96
All Time:
1,589
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide shows users how to replace the screen. By first taking the device apart until they can reach the screen so that they can replace it.
    1. VTech MobiGo Touch Learning System Screen Replacement, Case: step 1, image 1 of 1
      • Remove the battery covers and the four batteries.
      Ask FixBot
    2. VTech MobiGo Touch Learning System Screen Replacement: step 2, image 1 of 2 VTech MobiGo Touch Learning System Screen Replacement: step 2, image 2 of 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Ask FixBot
    3. VTech MobiGo Touch Learning System Screen Replacement: step 3, image 1 of 2 VTech MobiGo Touch Learning System Screen Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Ask FixBot
    1. VTech MobiGo Touch Learning System Screen Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 4, image 1 of 1
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Ask FixBot
    2. VTech MobiGo Touch Learning System Screen Replacement: step 5, image 1 of 1
      • Remove the three "L" shaped brackets and the spring.
      Ask FixBot
    3. VTech MobiGo Touch Learning System Screen Replacement: step 6, image 1 of 1
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Ask FixBot
    4. VTech MobiGo Touch Learning System Screen Replacement: step 7, image 1 of 1
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Ask FixBot
    1. VTech MobiGo Touch Learning System Screen Replacement, Screen: step 8, image 1 of 1
      • Remove the 4 (3.4 mm Philips J0) screws holding the screen in
      Ask FixBot
    2. VTech MobiGo Touch Learning System Screen Replacement: step 9, image 1 of 1
      • Remove the black tape
      Ask FixBot
    3. VTech MobiGo Touch Learning System Screen Replacement: step 10, image 1 of 1
      • Remove the circuit board from the back of the screen.
      • The circuit board has double sided tape on the back side holding it to the screen.
      Ask FixBot
    4. VTech MobiGo Touch Learning System Screen Replacement: step 11, image 1 of 1
      • Peel the ribbon wire off of the circuit board. Now the screen should be free to remove.
      Ask FixBot
    5. VTech MobiGo Touch Learning System Screen Replacement: step 12, image 1 of 1
      • Resolder the new screens ribbon cable on the the circuit board.
      • Always be careful when soldering.
      Ask FixBot
2 other people completed this guide.
Author
with
Daniel Kresge
409 Reputation
4 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
72 Guides authored
1 Guide Comment
mine i droped a rock on so i don’t get it
Jesse Eagan - Reply Share
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 96
All Time: 1,589
