Up to 20% off select tools
VTech MobiGo Touch Learning System Buttons Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
82
All Time:
1,881
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide show users how they can replace the buttons of the device.
    1. VTech MobiGo Touch Learning System Buttons Replacement, Case: step 1, image 1 of 1
      • Remove the battery covers and the four batteries.
      Ask FixBot
    2. VTech MobiGo Touch Learning System Buttons Replacement: step 2, image 1 of 2 VTech MobiGo Touch Learning System Buttons Replacement: step 2, image 2 of 2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      Ask FixBot
    3. VTech MobiGo Touch Learning System Buttons Replacement: step 3, image 1 of 2 VTech MobiGo Touch Learning System Buttons Replacement: step 3, image 2 of 2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      Ask FixBot
    1. VTech MobiGo Touch Learning System Buttons Replacement, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: step 4, image 1 of 1
      • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
      Ask FixBot
    2. VTech MobiGo Touch Learning System Buttons Replacement: step 5, image 1 of 1
      • Remove the three "L" shaped brackets and the spring.
      Ask FixBot
    3. VTech MobiGo Touch Learning System Buttons Replacement: step 6, image 1 of 1
      • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
      Ask FixBot
    4. VTech MobiGo Touch Learning System Buttons Replacement: step 7, image 1 of 1
      • Separate the front and back of the case.
      • Use a plastic opening tool if necessary.
      Ask FixBot
    1. VTech MobiGo Touch Learning System Buttons Replacement, Buttons: step 8, image 1 of 1
      • Remove 6 (3.8 mm Philips J0) screws holding the buttons in.
      Ask FixBot
    2. VTech MobiGo Touch Learning System Buttons Replacement: step 9, image 1 of 2 VTech MobiGo Touch Learning System Buttons Replacement: step 9, image 2 of 2
      • From here you can remove and replace the buttons.
      Ask FixBot
Author
with
Daniel Kresge
409 Reputation
4 Guides authored
USF Tampa, Team 8-3, Eyestone Fall 2015 Member of USF Tampa, Team 8-3, Eyestone Fall 2015
USFT-EYESTONE-F15S8G3
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 82
All Time: 1,881
