VTech Learning Tunes Karaoke Speaker Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
85
All Time:
1,268
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Is the sound not audible and/or distorted? This guide may help in finding a solution to fix the problem.
Tools
    1. VTech Learning Tunes Karaoke Speaker  Replacement, Speaker: step 1, image 1 of 1
      • To remove the battery door, loosen the screw using a Flathead screwdriver.
      • A coin can also be used to loosen the screw.
      Ask FixBot
    2. VTech Learning Tunes Karaoke Speaker  Replacement: step 2, image 1 of 2 VTech Learning Tunes Karaoke Speaker  Replacement: step 2, image 2 of 2
      • Remove the battery door and take out the batteries.
      Ask FixBot
    3. VTech Learning Tunes Karaoke Speaker  Replacement: step 3, image 1 of 1
      • Remove the six 9.5 mm Phillips #2 screws.
      • Remove the six 6.0 mm Phillips #2 screws.
      Ask FixBot
    4. VTech Learning Tunes Karaoke Speaker  Replacement: step 4, image 1 of 2 VTech Learning Tunes Karaoke Speaker  Replacement: step 4, image 2 of 2
      • Gently pull up on the rear panel.
      • Be careful to not pull on the wire connections.
      • Carefully place the back panel underneath the top panel with the tops facing each other, as shown in the picture.
      Ask FixBot
    5. VTech Learning Tunes Karaoke Speaker  Replacement: step 5, image 1 of 2 VTech Learning Tunes Karaoke Speaker  Replacement: step 5, image 2 of 2
      • Remove two 7.9 mm Phillips #1 screws on the speaker cover.
      • After removing the screws, remove the black plastic speaker cover to expose the speaker.
      Ask FixBot
    6. VTech Learning Tunes Karaoke Speaker  Replacement: step 6, image 1 of 1
      • Desolder the speaker at the solder points to remove.
      • Learn more about soldering and desoldering connections here.
      Ask FixBot
Gamuchirai Chifamba
249 Reputation
2 Guides authored
USF Tampa, Team 7-2, Cheng Spring 2016 Member of USF Tampa, Team 7-2, Cheng Spring 2016
USFT-CHENG-S16S7G2
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 85
All Time: 1,268
