VTech Kidizoom Smartwatch DX2 Battery Replacement
Views: 12K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
108
All Time:
11,991
Comments: 8
3 comments on steps, 5 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If your Smartwatch is not charging, and you tested the cables, then the battery may need to be replaced. This guide will show you how to do this.
Parts
Tools
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: step 1, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement, Master Switch: step 1, image 2 of 2
      • Begin by flipping the watch over with its back facing upwards.
      Ask FixBot
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 2, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 2, image 2 of 2
      • Next, use the Phillips #00 screwdriver to unscrew the four 6.0 mm screws located in each corner of the watch to remove the backplate.
      Ask FixBot
    3. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 3, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 3, image 2 of 2
      • Gently lift the backplate up to remove it.
      Ask FixBot
    4. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 1 of 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 2 of 3 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 4, image 3 of 3
      • After removing the backplate, lift the master switch up from the circuit board.
      Ask FixBot
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Motherboard: step 5, image 1 of 1
      • Using a Phillips #00 screwdriver, remove the 0.6 mm screw.
      Ask FixBot
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 6, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 6, image 2 of 2
      • Carefully remove the speaker from the case without disconnecting it from the motherboard.
      Ask FixBot
    3. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 7, image 1 of 2 VTech Kidizoom Smartwatch DX2 Battery Replacement: step 7, image 2 of 2
      Tool used on this step:
      Buy
      • Using the tweezers, carefully lift the bar holding the connection to the screen.
      • Remove the motherboard from the device.
      Ask FixBot
    1. VTech Kidizoom Smartwatch DX2 Battery Replacement, Battery: step 8, image 1 of 1
      • Carefully pry the battery off of the circuit board using the plastic opening tool.
      Ask FixBot
    2. VTech Kidizoom Smartwatch DX2 Battery Replacement: step 9, image 1 of 1
      • De-solder the wires connecting the battery to the circuit board.
      • Remove the battery.
      Ask FixBot
3 other people completed this guide.
Jessica Richard
515 Reputation
4 Guides authored
5 Guide Comments
Hey guys, My VTech watch is plugged in but once I turn it on it does but then shows a dead battery. I actually didn’t play with it for a while and I left it dead battery.
Gabriel Baker - Reply Share
So I might try this trick and see if it works.
Sometime i’ll try it
when I have the right tools
Can I cut the wires connected?
TECH DUDE - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 108
All Time: 11,991
