Up to 20% off select tools
VTech Kidizoom Camera Connect Shutter Button Replacement
Views: 2K
View statistics:
Past 24 Hours:
7
Past 7 Days:
30
Past 30 Days:
123
All Time:
2,010
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to remove and replace the button and circuit board used for taking photos
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: step 1, image 1 of 2 VTech Kidizoom Camera Connect Shutter Button Replacement, Front Case: step 1, image 2 of 2
      • Remove batteries and SD card before beginning disassembly!
      • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
      Ask FixBot
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: step 2, image 1 of 2 VTech Kidizoom Camera Connect Shutter Button Replacement: step 2, image 2 of 2
      • Remove all four (11mm) screws with the Philips #0 screwdriver.
      Ask FixBot
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: step 3, image 1 of 3 VTech Kidizoom Camera Connect Shutter Button Replacement: step 3, image 2 of 3 VTech Kidizoom Camera Connect Shutter Button Replacement: step 3, image 3 of 3
      • Remove the two battery cartridges located on the underside of the camera.
      • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
      Ask FixBot
    4. VTech Kidizoom Camera Connect Shutter Button Replacement: step 4, image 1 of 1
      • Beware of the two black viewfinder lens falling out as you pry open the device!
      • The device should now be open and ready for further repair and/or replacement parts.
      Ask FixBot
    1. VTech Kidizoom Camera Connect Shutter Button Replacement, Shutter Button: step 5, image 1 of 1
      • Remove the purple plastic that covers the button and circuit board. It should slide right out from the slot it sits in.
      Ask FixBot
    2. VTech Kidizoom Camera Connect Shutter Button Replacement: step 6, image 1 of 1
      • Unsolder wires connected to the right side of the circuit board. Pull the wires to the side.
      Ask FixBot
    3. VTech Kidizoom Camera Connect Shutter Button Replacement: step 7, image 1 of 2 VTech Kidizoom Camera Connect Shutter Button Replacement: step 7, image 2 of 2
      • The button/circuit board should be loose now. Gently pull out the button/circuit board to remove it from the device.
      Ask FixBot
Author
with
Justin Sanchez
544 Reputation
4 Guides authored
USF Tampa, Team 6-4, Eyestone Spring 2016 Member of USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 30
Past 30 Days: 123
All Time: 2,010
