VTech Kidizoom Camera Connect Motherboard Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
111
All Time:
3,289
Comments: 1
1 guide comment.
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to remove and replace the motherboard. Removing the motherboard allows you to access other components of the VTech Kidizoom Camera Connect.
Tools
    1. VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: step 1, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement, Front Case: step 1, image 2 of 2
      • Remove batteries and SD card before beginning disassembly!
      • Locate the four plastic screw covers denoted by the markers and gently pry them up with the metal spudger.
      Ask FixBot
    2. VTech Kidizoom Camera Connect Motherboard Replacement: step 2, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement: step 2, image 2 of 2
      • Remove all four (11mm) screws with the Philips #0 screwdriver.
      Ask FixBot
    3. VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 3, image 3 of 3
      • Remove the two battery cartridges located on the underside of the camera.
      • Once cartridges are removed, use the metal spudger to pry open the top, bottom, and both sides of the camera.
      Ask FixBot
    4. VTech Kidizoom Camera Connect Motherboard Replacement: step 4, image 1 of 1
      • Beware of the two black viewfinder lens falling out as you pry open the device!
      • The device should now be open and ready for further repair and/or replacement parts.
      Ask FixBot
    1. VTech Kidizoom Camera Connect Motherboard Replacement, Motherboard: step 5, image 1 of 1
      • Locate and remove the screws circled in the provided image with a Philips #0 screwdriver.
      Ask FixBot
    2. VTech Kidizoom Camera Connect Motherboard Replacement: step 6, image 1 of 2 VTech Kidizoom Camera Connect Motherboard Replacement: step 6, image 2 of 2
      • Unsolder the connection points on the motherboard.
      Ask FixBot
    3. VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 7, image 3 of 3
      • Unsolder the connections to the right battery terminal. Removing the terminal allows easier access to the motherboard.
      Ask FixBot
    4. VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 1 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 2 of 3 VTech Kidizoom Camera Connect Motherboard Replacement: step 8, image 3 of 3
      • Carefully pull up on the motherboard and pink plastic underneath the motherboard. The pink plastic contains the display and is connected to the motherboard.
      Ask FixBot
5 other people completed this guide.
Justin Sanchez
544 Reputation
4 Guides authored
USF Tampa, Team 6-4, Eyestone Spring 2016 Member of USF Tampa, Team 6-4, Eyestone Spring 2016
USFT-EYESTONE-S16S6G4
4 Members
60 Guides authored
1 Guide Comment
Do you know what the replacement mic is? My girls mic has stopped working. Sound still plays, but can’t record voice or sound for video making. Thanks Tim
Timothy GRAHAM - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 111
All Time: 3,289
