Up to 20% off select tools
VTech InnoTab Max Motherboard Replacement
Views: 2.9K
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
107
All Time:
2,860
Comments: 3
3 comments on steps.
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 minutes - 1 hour
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This guide will show how to replace the motherboard in the VTech Innotab Max.
    1. VTech InnoTab Max Motherboard Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Motherboard Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Motherboard Replacement, Cover: step 1, image 3 of 3
      • Remove all screw caps from the back panel using a metal spudger.
      Ask FixBot
    2. VTech InnoTab Max Motherboard Replacement: step 2, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 2, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 2, image 3 of 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Ask FixBot
    3. VTech InnoTab Max Motherboard Replacement: step 3, image 1 of 2 VTech InnoTab Max Motherboard Replacement: step 3, image 2 of 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Ask FixBot
    4. VTech InnoTab Max Motherboard Replacement: step 4, image 1 of 2 VTech InnoTab Max Motherboard Replacement: step 4, image 2 of 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Ask FixBot
    1. VTech InnoTab Max Motherboard Replacement, Battery: step 5, image 1 of 1
      • Once the back cover is removed the battery will be located in the bottom right as you can see in the image to the right.
      Ask FixBot
    2. VTech InnoTab Max Motherboard Replacement: step 6, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 6, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 6, image 3 of 3
      Tool used on this step:
      Plastic Cards
      $2.99
      Buy
      • Remove the tape holding down the wires, and carefully pry the battery off of the base of the device.
      • Pry carefully to avoid damaging the battery. The battery may start to bend slightly, this is normal and not a cause for concern.
      • It is best to use a plastic card or nylon spudger to remove the battery. Metal tools can puncture a battery, potentially causing a fire.
      Ask FixBot
    3. VTech InnoTab Max Motherboard Replacement: step 7, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 7, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 7, image 3 of 3
      • Now that the battery is free to be moved, unplug the wire connecting the battery to the motherboard.
      Ask FixBot
    4. VTech InnoTab Max Motherboard Replacement: step 8, image 1 of 1
      • The battery is now fully disconnected.
      Ask FixBot
    1. VTech InnoTab Max Motherboard Replacement, Camera: step 9, image 1 of 1
      • The camera is not held down by anything, so simply remove it from it's spot to prepare for unplugging it.
      Ask FixBot
    2. VTech InnoTab Max Motherboard Replacement: step 10, image 1 of 2 VTech InnoTab Max Motherboard Replacement: step 10, image 2 of 2
      • Carefully remove the wire connecting the camera to the motherboard, using a tool to grip it if needed.
      • Be careful to only pull from the end of the connector (closest to the motherboard), as the strip is easy to tear.
      Ask FixBot
    3. VTech InnoTab Max Motherboard Replacement: step 11, image 1 of 1
      • The camera is now removed completely removed from the device.
      Ask FixBot
    1. VTech InnoTab Max Motherboard Replacement, Screen: step 12, image 1 of 2 VTech InnoTab Max Motherboard Replacement, Screen: step 12, image 2 of 2
      • In order to unlock the screen you need to remove the 4 pins that can be seen in the picture.
      • To remove simply just turn and pull them out. Use a metal or nylon spudger if they are too small to grip.
      Ask FixBot
    2. VTech InnoTab Max Motherboard Replacement: step 13, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 13, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 13, image 3 of 3
      • Once the pins are removed the screen should be loose from the frame and only connected by the brown film pictured.
      Ask FixBot
    3. VTech InnoTab Max Motherboard Replacement: step 14, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 14, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 14, image 3 of 3
      Buy
      • In order to completely remove the screen you need to unclip the film from the motherboard by simply using a pair of tweezers and gently pulling.
      • Be careful not to tear the film when pulling.
      Ask FixBot
    4. VTech InnoTab Max Motherboard Replacement: step 15, image 1 of 2 VTech InnoTab Max Motherboard Replacement: step 15, image 2 of 2
      • Once unclipped from the motherboard the screen should be entirely free from the device
      Ask FixBot
    1. VTech InnoTab Max Motherboard Replacement, Motherboard: step 16, image 1 of 1
      • Remove the circled screws that are holding down the motherboard and components.
      • Every component that will need to be unscrewed will have wires running to it from the motherboard. These wires will not be disconnected.
      Ask FixBot
    2. VTech InnoTab Max Motherboard Replacement: step 17, image 1 of 3 VTech InnoTab Max Motherboard Replacement: step 17, image 2 of 3 VTech InnoTab Max Motherboard Replacement: step 17, image 3 of 3
      • With all of the screws out, lift up the speaker, the two visible bronze plates, and the small green chip at the top.
      • Do not try to disconnect any of the wires running to these devices, as you will not be able to reconnect them.
      • All of these components can be located by following wires leaving the motherboard.
      Ask FixBot
    3. VTech InnoTab Max Motherboard Replacement: step 18, image 1 of 1
      • With all of these components out of their place, lift up the motherboard to reveal one more bronze plate.
      • Remove the screws holding down this plate, and remove it with the rest of the motherboard.
      Ask FixBot
    4. VTech InnoTab Max Motherboard Replacement: step 19, image 1 of 1
      • All components should be free from the device, and you can now completely remove the motherboard.
      Ask FixBot
3 other people completed this guide.
Author
with
Jacob Schioppo
594 Reputation
4 Guides authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 107
All Time: 2,860
