Up to 20% off select tools
VTech InnoTab Max Cover Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
14
Past 30 Days:
88
All Time:
1,308
Comments: 1
1 comment on steps.
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
This guide will show any user how to replace the cover on a VTech InnoTab Max.
    1. VTech InnoTab Max Cover Replacement, Cover: step 1, image 1 of 3 VTech InnoTab Max Cover Replacement, Cover: step 1, image 2 of 3 VTech InnoTab Max Cover Replacement, Cover: step 1, image 3 of 3
      • Remove all screw caps from the back panel using a metal spudger.
      Ask FixBot
    2. VTech InnoTab Max Cover Replacement: step 2, image 1 of 3 VTech InnoTab Max Cover Replacement: step 2, image 2 of 3 VTech InnoTab Max Cover Replacement: step 2, image 3 of 3
      • Next remove all of the now uncovered screws.
      • If there is a cartridge in the device make sure to remove it.
      Ask FixBot
    3. VTech InnoTab Max Cover Replacement: step 3, image 1 of 2 VTech InnoTab Max Cover Replacement: step 3, image 2 of 2
      • Now that all of the screws have been removed, pry the back cover off using a plastic opening tool.
      Ask FixBot
    4. VTech InnoTab Max Cover Replacement: step 4, image 1 of 2 VTech InnoTab Max Cover Replacement: step 4, image 2 of 2
      • Here you can see the back cover has been fully removed and you can now access the front cover.
      • To remove the front cover, remove the springs holding the pictured brackets in place, then pull it away.
      Ask FixBot
Author
with
Alexander Bees
152 Reputation
1 Guide authored
USF Tampa, Team S5-G5, Lacy Spring 2017 Member of USF Tampa, Team S5-G5, Lacy Spring 2017
USFT-LACY-S17S5G5
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 88
All Time: 1,308
