Up to 20% off select tools
VTech InnoTab 2s Screen Replacement
Views: 1.5K
View statistics:
Past 24 Hours:
6
Past 7 Days:
24
Past 30 Days:
91
All Time:
1,474
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 30 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
By the end of this guide you should be able to access the screen on your tablet for removal or replacement.
    1. VTech InnoTab 2s Screen Replacement, Back Panel: step 1, image 1 of 1
      • Turn your device to where the back panel is facing you.
      Ask FixBot
    2. VTech InnoTab 2s Screen Replacement: step 2, image 1 of 2 VTech InnoTab 2s Screen Replacement: step 2, image 2 of 2
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      Ask FixBot
    3. VTech InnoTab 2s Screen Replacement: step 3, image 1 of 3 VTech InnoTab 2s Screen Replacement: step 3, image 2 of 3 VTech InnoTab 2s Screen Replacement: step 3, image 3 of 3
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      Ask FixBot
    4. VTech InnoTab 2s Screen Replacement: step 4, image 1 of 2 VTech InnoTab 2s Screen Replacement: step 4, image 2 of 2
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      Ask FixBot
    5. VTech InnoTab 2s Screen Replacement: step 5, image 1 of 2 VTech InnoTab 2s Screen Replacement: step 5, image 2 of 2
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      Ask FixBot
    1. VTech InnoTab 2s Screen Replacement, Motherboard: step 6, image 1 of 1
      • First begin by removing the three cross-head screws using a J0 bit.
      Ask FixBot
    2. VTech InnoTab 2s Screen Replacement: step 7, image 1 of 1
      • First remove the ribbon cables. There are two highlighted by the red squares
      • Do not apply too much pressure and make sure that the black plastic tabs are fully open before you pull the cable out.
      Ask FixBot
    3. VTech InnoTab 2s Screen Replacement: step 8, image 1 of 1
      • Remove the camera from the assembly and put is a safe place so that it will not get damaged.
      Ask FixBot
    4. VTech InnoTab 2s Screen Replacement: step 9, image 1 of 1
      • Remove the board from the main assembly.
      • Be careful not to pull too hard so that the cables aren't broken.
      Ask FixBot
    5. VTech InnoTab 2s Screen Replacement: step 10, image 1 of 1
      • De-solder the points shown to fully remove the cables and free the board.
      • A soldering guide offered by IFIXIT can be found here Soldering Skills.
      Ask FixBot
    1. VTech InnoTab 2s Screen Replacement, Screen: step 11, image 1 of 2 VTech InnoTab 2s Screen Replacement, Screen: step 11, image 2 of 2
      • After removing the back plate and screws, all screws have been removed to separate the circuit board and wires from the front panel.
      • Remove the front panel from the device to expose the screen.
      Ask FixBot
    2. VTech InnoTab 2s Screen Replacement: step 12, image 1 of 1
      • Using a heat gun, heat the glue that holds the screen to the rest of the device.
      • While heating, carefully pull screen from the device exposing the ribbon wire on the back of the screen, disconnect.
      Ask FixBot
Author
with
Esthevan Romeiro
261 Reputation
4 Guides authored
USF Tampa, Team 5-1, Lacy Fall 2016 Member of USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 24
Past 30 Days: 91
All Time: 1,474
