Up to 20% off select tools
VTech InnoTab 2s Back Panel Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
88
All Time:
908
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. VTech InnoTab 2s Back Panel Replacement, Back Panel: step 1, image 1 of 1
      • Turn your device to where the back panel is facing you.
      Ask FixBot
    2. VTech InnoTab 2s Back Panel Replacement: step 2, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 2, image 2 of 2
      • Lift the Leg all the way up and twist the bottom to remove.
      • Once the bottom part pops out the whole leg should just come off.
      • Remove any game cartridge from the device.
      Ask FixBot
    3. VTech InnoTab 2s Back Panel Replacement: step 3, image 1 of 3 VTech InnoTab 2s Back Panel Replacement: step 3, image 2 of 3 VTech InnoTab 2s Back Panel Replacement: step 3, image 3 of 3
      • Remove all of the plastic tabs on the device. These are covering screws that will need to be removed.
      • These covers are made of hard plastic so they may be difficult to remove.
      • There is a special tab in the cartridge cover that is made of rubber, make sure to not break this tab.
      Ask FixBot
    4. VTech InnoTab 2s Back Panel Replacement: step 4, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 4, image 2 of 2
      • Remove all nine screws from the back of the device using a J0 bit.
      • Remove the small battery.
      Ask FixBot
    5. VTech InnoTab 2s Back Panel Replacement: step 5, image 1 of 2 VTech InnoTab 2s Back Panel Replacement: step 5, image 2 of 2
      • Using a plastic opening tool, detach the backplate from the front piece.
      • Do not use excessive force. Double check that you removed all the screws if the panel is not coming off easily.
      • Once the backplate has been removed, you will have access to the circuit board.
      Ask FixBot
Author
with
Ricardo Espinosa
221 Reputation
2 Guides authored
USF Tampa, Team 5-1, Lacy Fall 2016 Member of USF Tampa, Team 5-1, Lacy Fall 2016
USFT-LACY-F16S5G1
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 88
All Time: 908
