VTech CS6719-2 Speaker Replacement
    1. VTech CS6719-2 Speaker Replacement, Battery: step 1, image 1 of 2 VTech CS6719-2 Speaker Replacement, Battery: step 1, image 2 of 2
      • Push down on the battery cover in the direction of the arrow located on the back of the phone.
      Ask FixBot
    2. VTech CS6719-2 Speaker Replacement: step 2, image 1 of 1
      • Pull the battery cover off of the back of the phone.
      Ask FixBot
    3. VTech CS6719-2 Speaker Replacement: step 3, image 1 of 1
      • Unplug the battery input cable.
      Ask FixBot
    4. VTech CS6719-2 Speaker Replacement: step 4, image 1 of 1
      • Lift the battery out of the back of the phone.
      Ask FixBot
    1. VTech CS6719-2 Speaker Replacement, Circuit Board: step 5, image 1 of 2 VTech CS6719-2 Speaker Replacement, Circuit Board: step 5, image 2 of 2
      • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
      Ask FixBot
    2. VTech CS6719-2 Speaker Replacement: step 6, image 1 of 1
      • Use the plastic opening tool and spudger to pry the back side of the phone off.
      Ask FixBot
    3. VTech CS6719-2 Speaker Replacement: step 7, image 1 of 2 VTech CS6719-2 Speaker Replacement: step 7, image 2 of 2
      • Remove the two 9mm screws located inside the back cover at the top.
      Ask FixBot
    1. VTech CS6719-2 Speaker Replacement, Speaker: step 8, image 1 of 1
      Tool used on this step:
      Buy
      • Locate the metal shaped U clip holding the speaker on. Pull up and towards the top of the phone with the flat head tweezers.
      • The clip is loose, it could fall out.
      Ask FixBot
    2. VTech CS6719-2 Speaker Replacement: step 9, image 1 of 1
      • Lift speaker out.
      Ask FixBot
    3. VTech CS6719-2 Speaker Replacement: step 10, image 1 of 1
      • Heat up solder joint on the circuit board where the speaker wires are connected.
      Ask FixBot
    4. VTech CS6719-2 Speaker Replacement: step 11, image 1 of 1
      Ask FixBot
Benjamin Field
277 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
2 Guide Comments
Where can I buy the speaker for the phone?
stephenandrewjarvis - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 29
All Time: 1,298
