VTech CS6719-2 Circuit Board Replacement
    1. VTech CS6719-2 Circuit Board Replacement, Battery: step 1, image 1 of 2 VTech CS6719-2 Circuit Board Replacement, Battery: step 1, image 2 of 2
      • Push down on the battery cover in the direction of the arrow located on the back of the phone.
      Ask FixBot
    2. VTech CS6719-2 Circuit Board Replacement: step 2, image 1 of 1
      • Pull the battery cover off of the back of the phone.
      Ask FixBot
    3. VTech CS6719-2 Circuit Board Replacement: step 3, image 1 of 1
      • Unplug the battery input cable.
      Ask FixBot
    4. VTech CS6719-2 Circuit Board Replacement: step 4, image 1 of 1
      • Lift the battery out of the back of the phone.
      Ask FixBot
    1. VTech CS6719-2 Circuit Board Replacement, Circuit Board: step 5, image 1 of 2 VTech CS6719-2 Circuit Board Replacement, Circuit Board: step 5, image 2 of 2
      • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
      Ask FixBot
    2. VTech CS6719-2 Circuit Board Replacement: step 6, image 1 of 1
      • Use the plastic opening tool and spudger to pry the back side of the phone off.
      Ask FixBot
    3. VTech CS6719-2 Circuit Board Replacement: step 7, image 1 of 2 VTech CS6719-2 Circuit Board Replacement: step 7, image 2 of 2
      • Remove the two 9mm screws located inside the back cover at the top.
      Ask FixBot
3 other people completed this guide.
Benjamin Field
277 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
1 Guide Comment
Thanks! Had to clean honey out if the speaker. Should Note the plastic quality is soft and can mark easily.
Jason Bellchamber - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 29
All Time: 823
