Up to 20% off select tools
VTech CS6719-2 Charging Wire Repair
Views: 2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
93
All Time:
2,019
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
During this guide, the base will need to be disassembled and then desolder the charging wire connections.
    1. VTech CS6719-2 Charging Wire Repair, Base: step 1, image 1 of 2 VTech CS6719-2 Charging Wire Repair, Base: step 1, image 2 of 2
      • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
      Ask FixBot
    2. VTech CS6719-2 Charging Wire Repair: step 2, image 1 of 1
      • Use the spudger to separate the bottom from the top.
      • There are two clips, located top and bottom, that you have to compress with the spudger.
      Ask FixBot
    1. VTech CS6719-2 Charging Wire Repair, Charging Wire: step 3, image 1 of 1
      • Heat up solder joint on the circuit board where the charging wires are connected. Note: This is the CRD- and CRD+ terminals.
      Ask FixBot
    2. VTech CS6719-2 Charging Wire Repair: step 4, image 1 of 1
      • Refer to How to Solder and Desolder connections How To Solder and Desolder Connections
      • Note: Ensure the old solder joint is removed.
      • Caution: Soldering iron and joint will become very hot.
      Ask FixBot
    3. VTech CS6719-2 Charging Wire Repair: step 5, image 1 of 1
      • Heat up solder joint on the base unit where the charging wires are connected.
      Ask FixBot
    4. VTech CS6719-2 Charging Wire Repair: step 6, image 1 of 1
      • Take a wire of solder and apply to joint on board to remove the extra solder.
      • Remove charging wire connection.
      Ask FixBot
Author
with
Josh Showalter
442 Reputation
3 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 93
All Time: 2,019
