Up to 20% off select tools
VTech CS6719-2 Base Fuse Replacement
Views: 3.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
16
Past 30 Days:
95
All Time:
3,312
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Difficult
Tools
Introduction
Go to step 1 ↓
During this guide, the base will need to be disassembled and the board flipped over to desolder the fuse connection.
    1. VTech CS6719-2 Base Fuse Replacement, Base: step 1, image 1 of 2 VTech CS6719-2 Base Fuse Replacement, Base: step 1, image 2 of 2
      • Remove the four Phillips #0 screws (9.4mm) located at the bottom of the phone on the back side of the base.
      Ask FixBot
    2. VTech CS6719-2 Base Fuse Replacement: step 2, image 1 of 1
      • Use the spudger to separate the bottom from the top.
      • There are two clips, located top and bottom, that you have to compress with the spudger.
      Ask FixBot
    1. VTech CS6719-2 Base Fuse Replacement, Base Fuse: step 3, image 1 of 1
      • Locate the fuse.
      Ask FixBot
    2. VTech CS6719-2 Base Fuse Replacement: step 4, image 1 of 1
      • Flip the board over.
      • Remember where the fuse is located.
      Ask FixBot
    3. Ask FixBot
    4. VTech CS6719-2 Base Fuse Replacement: step 6, image 1 of 1
      • Flip the board back over and remove the fuse.
      Ask FixBot
2 other people completed this guide.
Author
with
Nick Boyd
285 Reputation
2 Guides authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 95
All Time: 3,312
