Up to 20% off select tools
VTech CS6719-2 Screen Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
13
Past 30 Days:
85
All Time:
848
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 7 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
During this guide, the back of the phone and the circuit board will need to be taken off to access the plastic screen.
    1. VTech CS6719-2  Screen Replacement, Battery: step 1, image 1 of 2 VTech CS6719-2  Screen Replacement, Battery: step 1, image 2 of 2
      • Push down on the battery cover in the direction of the arrow located on the back of the phone.
      Ask FixBot
    2. VTech CS6719-2  Screen Replacement: step 2, image 1 of 1
      • Pull the battery cover off of the back of the phone.
      Ask FixBot
    3. VTech CS6719-2  Screen Replacement: step 3, image 1 of 1
      • Unplug the battery input cable.
      Ask FixBot
    4. VTech CS6719-2  Screen Replacement: step 4, image 1 of 1
      • Lift the battery out of the back of the phone.
      Ask FixBot
    1. VTech CS6719-2  Screen Replacement, Circuit Board: step 5, image 1 of 2 VTech CS6719-2  Screen Replacement, Circuit Board: step 5, image 2 of 2
      • Remove the two 9mm screws on the back side with a Phillips #0 screwdriver.
      Ask FixBot
    2. VTech CS6719-2  Screen Replacement: step 6, image 1 of 1
      • Use the plastic opening tool and spudger to pry the back side of the phone off.
      Ask FixBot
    3. VTech CS6719-2  Screen Replacement: step 7, image 1 of 2 VTech CS6719-2  Screen Replacement: step 7, image 2 of 2
      • Remove the two 9mm screws located inside the back cover at the top.
      Ask FixBot
    1. VTech CS6719-2  Screen Replacement, Screen: step 8, image 1 of 1
      • Remove the plastic screen.
      Ask FixBot
Author
with
Joshua Woodward
122 Reputation
1 Guide authored
IUPUI, Team 1-4, Baechle Spring 2016 Member of IUPUI, Team 1-4, Baechle Spring 2016
IUPUI-BAECHLE-S16S1G4
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 85
All Time: 848
