Up to 20% off select tools
VTech Baby's Learning Laptop Volume Switch Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
94
All Time:
1,552
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Has the sound for your device suddenly stopped working? Unable to adjust the volume? This guide may be the solution to your problem.
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Battery and Rear Panel: step 1, image 1 of 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Ask FixBot
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: step 2, image 1 of 1
      • Remove the battery door.
      • Take out the batteries.
      Ask FixBot
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: step 3, image 1 of 1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Ask FixBot
    4. VTech Baby's Learning Laptop Volume Switch  Replacement: step 4, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 4, image 2 of 2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Ask FixBot
    1. VTech Baby's Learning Laptop Volume Switch  Replacement, Volume Switch: step 5, image 1 of 1
      • Flip your device so the bottom panel is facing up.
      Ask FixBot
    2. VTech Baby's Learning Laptop Volume Switch  Replacement: step 6, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 6, image 2 of 2
      • Use a Phillips #2 screwdriver to remove the two 7.7mm screws on the volume switch.
      Ask FixBot
    3. VTech Baby's Learning Laptop Volume Switch  Replacement: step 7, image 1 of 2 VTech Baby's Learning Laptop Volume Switch  Replacement: step 7, image 2 of 2
      • Remove the volume switch.
      • Be careful not damage the wiring.
      Ask FixBot
Author
with
Jordan Smith
210 Reputation
2 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 94
All Time: 1,552
