VTech Baby's Learning Laptop Speaker Replacement
    1. VTech Baby's Learning Laptop Speaker Replacement, Battery and Rear Panel: step 1, image 1 of 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Ask FixBot
    2. VTech Baby's Learning Laptop Speaker Replacement: step 2, image 1 of 1
      • Remove the battery door.
      • Take out the batteries.
      Ask FixBot
    3. VTech Baby's Learning Laptop Speaker Replacement: step 3, image 1 of 1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Ask FixBot
    4. VTech Baby's Learning Laptop Speaker Replacement: step 4, image 1 of 2 VTech Baby's Learning Laptop Speaker Replacement: step 4, image 2 of 2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Ask FixBot
    1. VTech Baby's Learning Laptop Speaker Replacement, Speaker: step 5, image 1 of 2 VTech Baby's Learning Laptop Speaker Replacement, Speaker: step 5, image 2 of 2
      • Use a Phillips #0 screwdriver to unscrew the two 6.0 mm screws on the speaker.
      Ask FixBot
    2. VTech Baby's Learning Laptop Speaker Replacement: step 6, image 1 of 2 VTech Baby's Learning Laptop Speaker Replacement: step 6, image 2 of 2
      • Remove the two 6 mm screws from the device.
      • Remove the speaker.
      • Be careful not to damage the wiring.
      Ask FixBot
Jordan Smith
210 Reputation
2 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
84 Guides authored
2 Guide Comments
Where to buy the replacement speaker
hadbuckley - Reply Share
Where can you buy the replacement speaker please. I live in Sydney Australia
Past 24 Hours: 9
Past 7 Days: 27
Past 30 Days: 55
All Time: 1,916
