Up to 20% off select tools
VTech Baby's Learning Laptop LEDs Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
5
Past 7 Days:
28
Past 30 Days:
101
All Time:
1,896
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Do any of the lights on your device appear to be dimly lit or not come on at all? Replacing the LEDs may solve your problem.
    1. VTech Baby's Learning Laptop LEDs Replacement, LEDs: step 1, image 1 of 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Ask FixBot
    2. VTech Baby's Learning Laptop LEDs Replacement: step 2, image 1 of 1
      • Remove the battery door.
      • Take out the batteries.
      Ask FixBot
    3. VTech Baby's Learning Laptop LEDs Replacement: step 3, image 1 of 2 VTech Baby's Learning Laptop LEDs Replacement: step 3, image 2 of 2
      • Using a Phillips #0 screwdriver, unscrew the six 7.3mm screws holding the screen together.
      Ask FixBot
    4. VTech Baby's Learning Laptop LEDs Replacement: step 4, image 1 of 3 VTech Baby's Learning Laptop LEDs Replacement: step 4, image 2 of 3 VTech Baby's Learning Laptop LEDs Replacement: step 4, image 3 of 3
      • With the lid closed, position the device such that the handle is pointing towards you.
      • Using your fingers, gently pry open the cover from the hinge.
      • Attempting to remove the cover while the lid is still open may cause unwanted damage to the device.
      Ask FixBot
    5. VTech Baby's Learning Laptop LEDs Replacement: step 5, image 1 of 1
      • Remove two 6.0mm screws from the LED array using a Phillips #0 screwdriver.
      Ask FixBot
    6. VTech Baby's Learning Laptop LEDs Replacement: step 6, image 1 of 1
      • Pickup the array by the opening in the center of the board.
      • Remove the faulty LEDs by desoldering each from the board. You may refer to this soldering guide if necessary.
      • Movement of the array will be limited as it is still attached to the main device board.
      Ask FixBot
Author
with
Christopher Kourmoulakis
412 Reputation
3 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 28
Past 30 Days: 101
All Time: 1,896
