Up to 20% off select tools
VTech Baby's Learning Laptop Buttons Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
104
All Time:
1,647
Comments: 1
1 comment on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
Does your device not respond when buttons are pressed? Do only a few buttons seem to function correctly? This guide will walk through the steps required to replace the buttons.
    1. VTech Baby's Learning Laptop Buttons Replacement, Battery and Rear Panel: step 1, image 1 of 1
      • To remove the battery door, loosen the screw shown using a Phillips #2 screwdriver.
      • A coin can also be used to loosen the screw.
      Ask FixBot
    2. VTech Baby's Learning Laptop Buttons Replacement: step 2, image 1 of 1
      • Remove the battery door.
      • Take out the batteries.
      Ask FixBot
    3. VTech Baby's Learning Laptop Buttons Replacement: step 3, image 1 of 1
      • Remove the rear panel screws using a Phillips #2 screwdriver.
      • Two 21.6mm (Long)
      • One 9.8mm (Short)
      • Five 13.8mm (Medium)
      Ask FixBot
    4. VTech Baby's Learning Laptop Buttons Replacement: step 4, image 1 of 2 VTech Baby's Learning Laptop Buttons Replacement: step 4, image 2 of 2
      • Gently pull up on the rear panel.
      • Be careful not to pull on the wire connections.
      • Rest the laptop open on the table.
      Ask FixBot
    1. VTech Baby's Learning Laptop Buttons Replacement, Buttons: step 5, image 1 of 1
      • Using a Phillips #0 screwdriver remove the two 6.0mm screws.
      Ask FixBot
    2. VTech Baby's Learning Laptop Buttons Replacement: step 6, image 1 of 2 VTech Baby's Learning Laptop Buttons Replacement: step 6, image 2 of 2
      • Lift up on the board and set it aside.
      • Movement of the board will be limited. Be careful not to damage the connection to the motherboard.
      Ask FixBot
    3. VTech Baby's Learning Laptop Buttons Replacement: step 7, image 1 of 1
      • Remove each button and button contact.
      Ask FixBot
2 other people completed this guide.
Author
with
Christopher Kourmoulakis
412 Reputation
3 Guides authored
USF Tampa, Team 12-2, Blackwell Fall 2015 Member of USF Tampa, Team 12-2, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G2
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 104
All Time: 1,647
