VNLA Parfait Skates Wheel Replacement
  1. VNLA Parfait Skates Wheel Replacement, Wheel: step 1, image 1 of 2 VNLA Parfait Skates Wheel Replacement, Wheel: step 1, image 2 of 2
    • Place your skates on a flat surface for stability.
    • Ensure you have your new wheels and necessary tools within reach.
    Ask FixBot
  2. VNLA Parfait Skates Wheel Replacement: step 2, image 1 of 3 VNLA Parfait Skates Wheel Replacement: step 2, image 2 of 3 VNLA Parfait Skates Wheel Replacement: step 2, image 3 of 3
    • Use the PowerDyne Y3 Skate Tool to loosen the axle nuts on the first wheel by turning counterclockwise.
    • Keep the nuts in a safe place, as you will reuse them.
    Ask FixBot
  3. VNLA Parfait Skates Wheel Replacement: step 3, image 1 of 2 VNLA Parfait Skates Wheel Replacement: step 3, image 2 of 2
    • Slide the old wheel straight off the axle once the nut is removed.
    • Repeat the process for all wheels.
    Ask FixBot
  4. VNLA Parfait Skates Wheel Replacement: step 4, image 1 of 3 VNLA Parfait Skates Wheel Replacement: step 4, image 2 of 3 VNLA Parfait Skates Wheel Replacement: step 4, image 3 of 3
    • Place a bearing into the Bones Bearing Press/Puller and align it with the center of the new wheel.
    • Press down evenly and firmly until the bearing is fully seated.
    • Flip the wheel and repeat for the second bearing.
    • Do this for all wheels.
    Ask FixBot
  5. VNLA Parfait Skates Wheel Replacement: step 5, image 1 of 3 VNLA Parfait Skates Wheel Replacement: step 5, image 2 of 3 VNLA Parfait Skates Wheel Replacement: step 5, image 3 of 3
    • Slide the new wheels onto the skate axles.
    • Secure each wheel with the axle nut, turning it clockwise with the PowerDyne Y3 Skate Tool.
    Ask FixBot
  6. VNLA Parfait Skates Wheel Replacement: step 6, image 1 of 1
    • Spin each wheel by hand to check for smooth rotation.
    • If a wheel is too tight, slightly loosen the axle nut.
    • If it’s too loose, tighten it just enough to prevent wobbling.
    Ask FixBot
Finish Line
Julie McMullen
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 24
Past 30 Days: 38
All Time: 240
