Up to 20% off select tools
VIA GO with SSD
View statistics:
Past 24 Hours:
Past 7 Days:
10
Past 30 Days:
79
All Time:
92
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Community-Contributed Guide
VIA GO with SSD
Introduction
Go to step 1 ↓
Guide to modify 50.4SU17.021 (or 50.4SU17.031) flex cable to be compatible with VIA-GO connector!
!!! DO NOT USE CABLE AS IS! ORIGINAL CABLE PINOUT WILL SHORT 5V RAIL TO THE GROUND!
cable has identical 20-pin connector, where SATA pins are correctly soldered, but other pins must be soldered complitly differently.
    1. VIA GO with SSD, the cable: step 1, image 1 of 3 VIA GO with SSD, the cable: step 1, image 2 of 3 VIA GO with SSD, the cable: step 1, image 3 of 3
      • cable overview and 20-pin connector closeup.
      Ask FixBot
    2. VIA GO with SSD, cable pinout before: step 2, image 1 of 3 VIA GO with SSD, cable pinout before: step 2, image 2 of 3 VIA GO with SSD, cable pinout before: step 2, image 3 of 3
      • cable pinout is not compatible with VIA-GO until it is modified!
      Ask FixBot
    3. VIA GO with SSD, cable pinout after: step 3, image 1 of 3 VIA GO with SSD, cable pinout after: step 3, image 2 of 3 VIA GO with SSD, cable pinout after: step 3, image 3 of 3
      • 20-pin connector on motherboard have (3pin)5V and (1pin)3.3V.
      • using only 5V since my SSD do not utilize 3.3V at all.
      Ask FixBot
    4. VIA GO with SSD, result: step 4, image 1 of 2 VIA GO with SSD, result: step 4, image 2 of 2
      • SSD is now recognized and fully functional! there is not much space in the case, so SSD's casing is removed.
      • BIOS (default) admin password is v14goxxx. use it to verify/change settings (is not necessary to be able install and boot form SSD).
      Ask FixBot
Author
with
Artur Huhtaniemi
373 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 79
All Time: 92
