Up to 20% off select tools
VENSTAR Taco Microphone Replacement Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
17
Past 30 Days:
105
All Time:
775
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Tools
Introduction
Go to step 1 ↓
Here we will be removing the small michrophone in the back of the taco. This task requires removing the logic board before it may be reached.
    1. VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement, VENSTAR Taco Disassembly: step 1, image 3 of 3
      • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
      • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
      Ask FixBot
    2. VENSTAR Taco Microphone Replacement Replacement: step 2, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 2, image 2 of 2
      • Repeat the previous step on the opposite side to remove the other outer casing.
      Ask FixBot
    3. VENSTAR Taco Microphone Replacement Replacement: step 3, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 3, image 2 of 2
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
      • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
      Ask FixBot
    4. VENSTAR Taco Microphone Replacement Replacement: step 4, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 4, image 2 of 2
      • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
      Ask FixBot
    5. VENSTAR Taco Microphone Replacement Replacement: step 5, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 5, image 2 of 2
      • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
      Ask FixBot
    1. VENSTAR Taco Microphone Replacement Replacement, Logic Board Replacement: step 6, image 1 of 1
      • Remove the rubber covering from the buttons.
      Ask FixBot
    2. VENSTAR Taco Microphone Replacement Replacement: step 7, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement: step 7, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement: step 7, image 3 of 3
      • Remove the black fabric covering the logic board.
      Ask FixBot
    3. VENSTAR Taco Microphone Replacement Replacement: step 8, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 8, image 2 of 2
      • Move the battery out of the way of the connector.
      Ask FixBot
    4. VENSTAR Taco Microphone Replacement Replacement: step 9, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement: step 9, image 2 of 2
      • Undo the connector of the flat white ribbon between the switches and the logic board.
      Ask FixBot
    5. VENSTAR Taco Microphone Replacement Replacement: step 10, image 1 of 1
      • Undo the two black 3mm screws on the logic board using the PH0 screwdriver.
      Ask FixBot
    6. VENSTAR Taco Microphone Replacement Replacement: step 11, image 1 of 3 VENSTAR Taco Microphone Replacement Replacement: step 11, image 2 of 3 VENSTAR Taco Microphone Replacement Replacement: step 11, image 3 of 3
      • Gently pull out the logic board.
      • Note that the battery and the logic board are connected and must be removed together.
      Ask FixBot
    1. VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: step 12, image 1 of 2 VENSTAR Taco Microphone Replacement Replacement, Microphone Replacement: step 12, image 2 of 2
      • Below the logic board, the small black microphone is resting within the case.
      Ask FixBot
Author
with
Kaylee Simms
310 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 17
Past 30 Days: 105
All Time: 775
