Up to 20% off select tools
VENSTAR Taco Disassembly
Views: 1K
View statistics:
Past 24 Hours:
Past 7 Days:
15
Past 30 Days:
93
All Time:
1,021
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
There is no visible way to open this device. Knowing this, assembly and disassembly must be done carefully in order to maintain the integrity of the device.
    1. VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 1 of 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 2 of 3 VENSTAR Taco Disassembly, VENSTAR Taco Disassembly: step 1, image 3 of 3
      • Starting with the Taco on its side, use the plastic opening tool to pop off the outer casing near the base.
      • The base labeled "VENSTAR TACO" is glued. Be careful separating the two sides of the device.
      Ask FixBot
    2. VENSTAR Taco Disassembly: step 2, image 1 of 2 VENSTAR Taco Disassembly: step 2, image 2 of 2
      • Repeat the previous step on the opposite side to remove the other outer casing.
      Ask FixBot
    3. VENSTAR Taco Disassembly: step 3, image 1 of 2 VENSTAR Taco Disassembly: step 3, image 2 of 2
      Tool used on this step:
      Phillips #0 Screwdriver
      $5.49
      Buy
      • Using a Phillips PH0 3 mm-bit screwdriver, remove the six screws on the inner layer of the Taco.
      • The screws are small and can get stuck. Use tweezers to pull them out if you are having trouble.
      Ask FixBot
    4. VENSTAR Taco Disassembly: step 4, image 1 of 2 VENSTAR Taco Disassembly: step 4, image 2 of 2
      • From the same side you just unscrewed, use a plastic opening tool to unwedge the inner cover on both sides of the base.
      Ask FixBot
    5. VENSTAR Taco Disassembly: step 5, image 1 of 2 VENSTAR Taco Disassembly: step 5, image 2 of 2
      • Slide off the inner cover. It pulls apart and is held on by a small amount of glue.
      Ask FixBot
Author
with
Michael Thompson
200 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 15
Past 30 Days: 93
All Time: 1,021
