Up to 20% off select tools
V-Moda Crossfade II Wireless Driver Assembly Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
15
Past 30 Days:
78
All Time:
356
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 45 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Tools
Introduction
Go to step 1 ↓
If your V-Moda Crossfade II Wireless has no audio or muffled audio you will need to replace your Speaker Driver.
However before disassembling your V-Moda Crossfade II Wireless take a look at this trouble shooting guide V-Moda Crossfade II Wireless Audio is Distorted or Intermittent to see if it fixes your issues.
Just follow these simple steps and you'll be able to do it yourself. For this guide you will need a Phillips #00 screwdriver head, some experience in soldering, and the soldering equipment that is listed on the right-hand side.
This guide requires soldering. If you're unfamiliar with soldering, review the How to Solder and Desolder Connections guide and take appropriate precautions before beginning.
    1. V-Moda Crossfade II Wireless Driver Assembly Replacement, Ear Pad: step 1, image 1 of 1
      • Search for the left/right side of the V-moda Crossfade II Wireless.
      • The left side has a grey letter L whilst the right side has a red letter R on top of the speaker.
      • Pinch the bottom of the ear pad and lift it up to remove it.
      Ask FixBot
    1. V-Moda Crossfade II Wireless Driver Assembly Replacement, Driver Assembly: step 2, image 1 of 2 V-Moda Crossfade II Wireless Driver Assembly Replacement, Driver Assembly: step 2, image 2 of 2
      • Remove all six 10.1 mm screws that secures the driver assembly that you need to replace with a Phillips screwdriver.
      • Lift off the driver assembly with care not to strain the connected wire.
      Ask FixBot
    2. V-Moda Crossfade II Wireless Driver Assembly Replacement: step 3, image 1 of 1
      • Desolder the driver assembly connections.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Author
with
Ashton Soukanya
228 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 15
Past 30 Days: 78
All Time: 356
