Up to 20% off select tools
Using the 3DS's Safe Mode
Views: 18K
View statistics:
Past 24 Hours:
15
Past 7 Days:
85
Past 30 Days:
425
All Time:
17,956
Comments: 5
1 comment on steps, 4 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide demonstrates how to use SAFE_MODE, a 3DS family recovery feature which can fix damaged system titles, as well as other software issues by forcing a system update. It's demonstrated here on a 2DS XL, but the process is the same for all 3DS (and 2DS) systems.
    1. Using the 3DS's Safe Mode, Booting safe mode: step 1, image 1 of 1
      • Ensure the console is powered off
      • Hold the (L) + (R) + (A) + (D-Pad Up) buttons
      • Keep these buttons held down until the console boots in the next step
      • While still holding the other buttons, press the power button
      Ask FixBot
    2. Using the 3DS's Safe Mode, Updating the System: step 2, image 1 of 3 Using the 3DS's Safe Mode, Updating the System: step 2, image 2 of 3 Using the 3DS's Safe Mode, Updating the System: step 2, image 3 of 3
      • You should boot into a "system update" screen. Click OK and accept the prompts
      • If there's no working internet connection configured on your 3ds, you'll have the option to set one up now
      Ask FixBot
    3. Using the 3DS's Safe Mode: step 3, image 1 of 1
      • When the update finishes, the console will automatically turn off
      Ask FixBot
If your issue persists after following this guide, a system format may fix it. Or, if you'd prefer to keep your data, you can ask a question
4 other people completed this guide.
Author
with
darth mango
3,910 Reputation
3 Guides authored
4 Guide Comments
Does this work on old family 3ds?
maxxy waxxy - Reply Share
Works on every 3ds and 2ds model
darth mango - Reply Share
Hello Darth mango. I have had my 3ds xl (red btw) since 2016. It stopped working in 19 and I gave up. Never knew why, but when I tried this it didn't work. I see u have a reputation for fixing this stuff and I followed EVERY one of our guides. Nothing works. Should I just just go get it repaired, because NOTHING will work, even this.
Jahasen :D - Reply Share
Can you post a question about this? I try to avoid troubleshooting in comments as opposed to the forum made for it. Remember to include any symptoms (what happens when you plug it in, try to turn it on, etc.) as well as what fixes you've already tried. The better the info you give us, the better we'll be able to help. :D
Past 24 Hours: 15
Past 7 Days: 85
Past 30 Days: 425
All Time: 17,956
