Using a Jack
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Using a Jack, Using a Jack: step 1, image 1 of 2 Using a Jack, Using a Jack: step 1, image 2 of 2
    • Identify the jack point, located directly underneath your car, in the center portion between the front two wheels.
    • Place the Hydraulic Jack beneath the jack point.
    • Pump the lever on the Hydraulic Jack, up and down, until the jack makes contact with the jack point. (Adjust the placement if necessary).
    • Continue pumping the lever until the wheels are two inches off the ground.
    Ask FixBot
  2. Using a Jack: step 2, image 1 of 2 Using a Jack: step 2, image 2 of 2
    • Identify the jack points located behind each front tire. Place a Jack Stand underneath both jack points.
    • Clear the area underneath the car of people or debris. Make sure the jack stands are properly supporting the car.
    • Slowly rotate the Hydraulic Jack counter-clockwise to lower it. (Half a turn should be enough.)
    • After fully lowering the Hydraulic Jack, remove it from underneath your car.
    Ask FixBot
To remove jack stands, follow guide in reverse order, remembering that lowering and raising the Pneumatic Jack require different actions.
Matt Ondriezek
486 Reputation
3 Guides authored
Cal Poly, Team 12-35, Maness Spring 2014 Member of Cal Poly, Team 12-35, Maness Spring 2014
CPSU-MANESS-S14S12G35
4 Members
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 13
Past 30 Days: 41
All Time: 1,230
