Up to 20% off select tools
Using a Floor Jack
Views: 45K
View statistics:
Past 24 Hours:
12
Past 7 Days:
54
Past 30 Days:
270
All Time:
45,272
Comments: 4
4 comments on steps.
Completed: 8
8 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Better Introduction
Improve this guide by completing or revising its introduction.
Using a Floor Jack
    1. Using a Floor Jack, Using a Floor Jack: step 1, image 1 of 2 Using a Floor Jack, Using a Floor Jack: step 1, image 2 of 2
      • Place the hydraulic floor jack under the vehicle until the saddle is directly under the crossmember.
      • The crossmember is the long metal support beam that runs underneath from the front fender to the rear fender on both sides of the car.
      • The saddle is the round metal part of the jack that moves upward as you pump the jack up.
      Ask FixBot
    2. Using a Floor Jack, Using floor jack to lift car.: step 2, image 1 of 1
      • Push downward on the jack's lever to lift the saddle upward so that it contacts the crossmember. Continue pushing downward on the lever to lift the car upward.
      Ask FixBot
    3. Using a Floor Jack: step 3, image 1 of 1
      • Place the jack stand under the jack mounting point.
      • The jack mounting point is a metallic protrusion beneath each of the car doors.
      Ask FixBot
    4. Using a Floor Jack: step 4, image 1 of 1
      • Raise the jack stand until it contacts the jack mounting point.
      • In the event the floor jack fails, the jack stand is designed to prevent the car from falling.
      Ask FixBot
8 other people completed this guide.
Author
with
Shaun MacDonald
2,669 Reputation
8 Guides authored
Cal Poly, Team 24-27, Regan Fall 2012 Member of Cal Poly, Team 24-27, Regan Fall 2012
CPSU-REGAN-F12S24G27
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 12
Past 7 Days: 54
Past 30 Days: 270
All Time: 45,272
