Up to 20% off select tools
Upper Ice Maker Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
79
All Time:
703
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 45 minutes - 1 hour
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Use this guide to disassemble the upper ice maker assembly to replace the upper ice maker on your LG model LFX25973 refrigerator.
This ice maker provides ice for the through-door dispenser. If it fails, ice will not be available to dispense.
The assembly has both the ice maker and the auger motor. If the ice maker alone fails, you can replace it on the assembly.
    1. Upper Ice Maker Replacement, Unplug your refrigerator: step 1, image 1 of 1
      • Unplug your refrigerator before you begin your repair.
      • If you are testing or repairing the following items, you may also need to shut off and disconnect the water supply:
      • Condenser Fan Motor
      • Compressor Motor and Thermal Overload Device
      • Water Supply Valve Assembly
      Ask FixBot
    1. Upper Ice Maker Replacement, Open the doors: step 2, image 1 of 3 Upper Ice Maker Replacement, Open the doors: step 2, image 2 of 3 Upper Ice Maker Replacement, Open the doors: step 2, image 3 of 3
      • Open both refrigerator doors fully.
      Ask FixBot
    1. Upper Ice Maker Replacement, Open the ice maker door: step 3, image 1 of 3 Upper Ice Maker Replacement, Open the ice maker door: step 3, image 2 of 3 Upper Ice Maker Replacement, Open the ice maker door: step 3, image 3 of 3
      • Pull down the latch handle to release the ice maker door.
      • Swing open the ice maker door.
      Ask FixBot
    2. Upper Ice Maker Replacement, Remove the ice bucket: step 4, image 1 of 3 Upper Ice Maker Replacement, Remove the ice bucket: step 4, image 2 of 3 Upper Ice Maker Replacement, Remove the ice bucket: step 4, image 3 of 3
      • Using two hands, lift up the ice bucket slightly to release it.
      • Pull the bottom edge of the ice bucket toward you slightly and remove it.
      Ask FixBot
    3. Upper Ice Maker Replacement, Reassembly notes: step 5, image 1 of 3 Upper Ice Maker Replacement, Reassembly notes: step 5, image 2 of 3 Upper Ice Maker Replacement, Reassembly notes: step 5, image 3 of 3
      • The drive hub notches and drive blade wings must line up before installing the ice bucket.
      • Rotate the ice bucket hub, located on the rear of the ice bucket, with your hand so that the notches will align with the auger motor drive blades.
      Ask FixBot
    1. Upper Ice Maker Replacement, Remove the ice maker assembly screws: step 6, image 1 of 2 Upper Ice Maker Replacement, Remove the ice maker assembly screws: step 6, image 2 of 2
      • Use a #2 Philips driver to remove the three 15 mm‑long screws that secure the ice maker assembly to the refrigerator door.
      Ask FixBot
    2. Upper Ice Maker Replacement, Reposition the ice maker assembly: step 7, image 1 of 3 Upper Ice Maker Replacement, Reposition the ice maker assembly: step 7, image 2 of 3 Upper Ice Maker Replacement, Reposition the ice maker assembly: step 7, image 3 of 3
      • Use a spudger to lift the bottom edge of the ice maker assembly. This action will release the assembly from the refrigerator door.
      • Pull the bottom edge of the ice maker assembly toward you to free it from the door.
      Ask FixBot
    3. Upper Ice Maker Replacement: step 8, image 1 of 3 Upper Ice Maker Replacement: step 8, image 2 of 3 Upper Ice Maker Replacement: step 8, image 3 of 3
      • Lower the ice maker assembly until you can access the connector located at the top of the assembly.
      • Squeeze the connector at the top of the ice maker assembly to release it.
      • Pull the connector straight down to disconnect it.
      Ask FixBot
    4. Upper Ice Maker Replacement, Remove the ice maker assembly: step 9, image 1 of 1
      • Remove the ice maker assembly.
      Ask FixBot
    1. Upper Ice Maker Replacement, Remove the air duct from the ice maker: step 10, image 1 of 1
      • Use a Phillips screwdriver to remove the 14.4 mm‑long air duct screw from the side of the ice maker assembly.
      • The air duct gasket partially covers this screw.
      Ask FixBot
    2. Upper Ice Maker Replacement: step 11, image 1 of 2 Upper Ice Maker Replacement: step 11, image 2 of 2
      • Remove the air duct.
      Ask FixBot
    3. Upper Ice Maker Replacement, Remove the circuit board cover: step 12, image 1 of 1
      • Use a Phillips screwdriver to remove the two 32.5 mm‑long screws securing the circuit board cover.
      Ask FixBot
    4. Upper Ice Maker Replacement: step 13, image 1 of 2 Upper Ice Maker Replacement: step 13, image 2 of 2
      • Open the circuit board cover.
      • The circuit board cover has wires that must be disconnected before removing the ice maker.
      Ask FixBot
    5. Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: step 14, image 1 of 2 Upper Ice Maker Replacement, Disconnect the ice maker wiring harness: step 14, image 2 of 2
      • Squeeze the three-wire connector to release it from the circuit board.
      • Pull the three-wire connector straight out to disconnect it.
      Ask FixBot
    6. Upper Ice Maker Replacement: step 15, image 1 of 3 Upper Ice Maker Replacement: step 15, image 2 of 3 Upper Ice Maker Replacement: step 15, image 3 of 3
      • Squeeze the multi-wire connector with the two orange wires running to the on/off switch.
      • Pull the connector straight out to disconnect it.
      Ask FixBot
    7. Upper Ice Maker Replacement: step 16, image 1 of 3 Upper Ice Maker Replacement: step 16, image 2 of 3 Upper Ice Maker Replacement: step 16, image 3 of 3
      • Use long nose pliers to pull the two spade connectors straight off the on-off switch terminals.
      Ask FixBot
    8. Upper Ice Maker Replacement, Unfasten the ice maker from the back plate: step 17, image 1 of 1
      • Use a Phillips screwdriver to remove the three 16.5 mm‑long screws securing the ice maker to the back plate.
      Ask FixBot
    9. Upper Ice Maker Replacement, Remove the ice maker from the back plate: step 18, image 1 of 2 Upper Ice Maker Replacement, Remove the ice maker from the back plate: step 18, image 2 of 2
      • Lift the ice maker off the back plate and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our  Answers community for help.
Author
with
Bill Gilbert
41,156 Reputation
261 Guides authored
iFixit Member of iFixit
Staff
119 Members
72,966 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 79
All Time: 703
