Up to 20% off select tools
Unresponsive keyboard fix
Views: 178K
View statistics:
Past 24 Hours:
4
Past 7 Days:
45
Past 30 Days:
176
All Time:
178,273
Comments: 74
11 comments on steps, 63 guide comments.
Go to guide comments
Completed: 96
96 people have marked this guide "completed." Will you be next?
Favorites: 15
15 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Tools
  • Pro Tech Go Toolkit
    $42.46 $49.95
    4.9
    Pry tools, T5 Torx and Phillips #1 required - if you have these, you can skip this.
Introduction
Go to step 1 ↓
After a few weeks of use, some keys of my Zenbook keyboard became unresponsive. In my case, it was the vertical key rows. After opening my laptop I noticed the cable was unlocked. This guide will show you how to reconnect it.
This fix may not work in every scenario and is not guaranteed to work. This is a noninvasive fix you can try before sending the laptop out for repair or buying a new palmrest assembly.
    1. Unresponsive keyboard fix, Remove the bottom cover: step 1, image 1 of 1
      • Note: These 2 screws are longer then the others.
      • Unscrew the remaining 8 screws. These are all the same length.
      Ask FixBot
    2. Unresponsive keyboard fix, Remove the battery: step 2, image 1 of 1
      • Remove the back cover. There are no warranty stickers that need to be broken.
      • Locate the keyboard connector. It is covered with a piece of tape helping hold it in place. This tape often fails after a certain amount of time.
      • You may need to remove the battery to disconnect it. Unscrew the 3 screws holding the battery in the system.
      Ask FixBot
    3. Unresponsive keyboard fix, Reconnect the keyboard: step 3, image 1 of 1
      • Note: New tape should be added once reseated.
      • Remove the tape covering the connector.
      • Here on the picture you can see the connector in the unlocked position. These hold the connector in and should be completely pushed in.
      • Push the connector in. Do this until it is secure.
      • Lock the tabs that retain the keyboard connector in place.
      Ask FixBot
Screw everything back and if you've done it right, enjoy all your keyboard keys again.
96 other people completed this guide.
Author
with
Francis
1,784 Reputation
1 Guide authored
63 Guide Comments
Awesome fix, thanks! This exact issue was plaguing the up and down keys on my UX31 (this is after having to RMA the thing for power issues). Be forewarned, if you are attempting this on a machine that is in sleep or hibernation mode, it has the potential to shut it off, with no visible LED lights to indicate. You can reset by holding down the power button for ~10 seconds and it should boot back up, if not, check connections again.
The LED light on the charging cable is a decent indication if something's up or not.
Jeff L - Reply Share
Yep, this worked on my zenbook UX31A. The two white push tabs have to be fully in for the wires in the ribbon cable to contact. When u push in one, the other one pops open, so push both together.
Also, MY zenbook needed a torx T4 to unscrew the screws.
spud - Reply Share
Great fix! My shift keys were not registering, and upon removing the back I saw the keyboard connector was indeed loose. Securing it in place fixed the problem. Thanks a lot!
Adolfo Brandes - Reply Share
Thanks for this! I had random keys unresponsive at various times, my white connector was plugged in on one side but not the other. See-sawed it back and forth until they were both in.
I think the cause is the battery; it physically places the keyboard cable under stress. I replaced the tape with much stronger stuff but am not sure if it will be a permanent fix...
Jonathan - Reply Share
Thanks man, you are the best!! This is a great notebook, and this problem was starting to make me hate it. Easy as cake. Wish you good fortune and the best of luck.
Saturnin Kepa - Reply Share
Past 24 Hours: 4
Past 7 Days: 45
Past 30 Days: 176
All Time: 178,273
