Up to 20% off select tools
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Unihertz Atom speaker Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
12
Past 30 Days:
63
All Time:
443
Comments: 2
2 guide comments.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 40 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
Test whether the speaker for answering phone calls works and change it if necessary. This guide works for Unihertz Atom, not Unihertz Atom XL or any other model.
I suspect that my speaker is broken because water got into it.
You need a speaker that fits the Unihertz Atom's size. It should be 8*9*2.3mm (2~2.3mm). The seller said it also works for another Huawei phone.
To find the speaker, I asked many cellphone parts sellers whether they have speakers in this size. Contact me if you cannot find one; I still have 2 speakers.
See also:
    1. Unihertz Atom speaker Replacement, Remove the rear case: step 1, image 1 of 1
      • Remove the 8 screws on the rear case and remove the rear case.
      Ask FixBot
    2. Unihertz Atom speaker Replacement, Remove the loudspeaker screws: step 2, image 1 of 1
      • Remove the 2 screws on the loudspeaker assembly
      Ask FixBot
    3. Unihertz Atom speaker Replacement, Remove the loudspeaker: step 3, image 1 of 1
      • Remove the loudspeaker assembly
      Ask FixBot
    4. Unihertz Atom speaker Replacement, Remove the battery: step 4, image 1 of 1
      • Pry up the cable connector attaching the battery to the motherboard and remove the battery.
      Ask FixBot
    5. Unihertz Atom speaker Replacement, Remove the camera screws: step 5, image 1 of 1
      • Remove the screws from the camera assembly. Pry open the cable connector at the connection between the camera assembly and the motherboard.
      Ask FixBot
    6. Unihertz Atom speaker Replacement, Remove the camera: step 6, image 1 of 1
      • Remove the camera assembly
      Ask FixBot
    7. Unihertz Atom speaker Replacement, Replace the speaker: step 7, image 1 of 1
      • You can now see the earpiece speaker.
      • Test it with an ohmmeter. Measure its resistance between the left and right metal legs. If it does not make noise while measuring, it is broken.
      • It is adhered to the phone; remove it using a flathead screwdriver or similar tool.
      • Place the new speaker into position. In my case, it works fine without glue.
      Ask FixBot
      • Reassemble the device.
      • Be careful while installing the camera module, as the cable may appear to fit even if it is in the wrong position. If the camera does not work after you reboot the phone, the cable may be misaligned.
      Ask FixBot
Follow the instructions in reverse order for the reassembly of your device.
Author
with
chair
157 Reputation
1 Guide authored
2 Guide Comments
@midori I see you delete the speaker's page (https://zh.ifixit.com/Item/History/speak...) , which is a very important part in this guide.
Can you explain why you do so? or where can I upload the photo of the speaker?
chair - Reply Share
Hey, @midori , since you does not explain your deletion, I recover the old speaker page (speaker module for unihertz atom). Please tell me if it is not appropriate.
chair - Reply Share
Past 24 Hours: 2
Past 7 Days: 12
Past 30 Days: 63
All Time: 443
