Up to 20% off select tools
Uniden UTAB71 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
83
All Time:
990
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 8 - 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will explain how to replace the screen of a UTAB71.
    1. Uniden UTAB71 Screen Replacement, Screen: step 1, image 1 of 2 Uniden UTAB71 Screen Replacement, Screen: step 1, image 2 of 2
      • Use a pry tool to undo the clips that attach the two halves of the tablet.
      • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
      • Make sure the tablet is powered off before prying open.
      • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
      Ask FixBot
    2. Uniden UTAB71 Screen Replacement: step 2, image 1 of 2 Uniden UTAB71 Screen Replacement: step 2, image 2 of 2
      • Lift off the black clip connecting the first power ribbon to the motherboard
      • Undo the clips off the second power ribbon connecting the screen to the motherboard.
      Ask FixBot
    3. Uniden UTAB71 Screen Replacement: step 3, image 1 of 3 Uniden UTAB71 Screen Replacement: step 3, image 2 of 3 Uniden UTAB71 Screen Replacement: step 3, image 3 of 3
      • Slowly remove the screen component off the tablet by clipping the screen from the tablet outine
      • Do not apply too much pressure on the tablet casing.
      Ask FixBot
Author
with
Ryan Jewell
443 Reputation
4 Guides authored
UMass Dartmouth, Team 5-4, Martin Fall 2016 Member of UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 83
All Time: 990
