Up to 20% off select tools
Uniden UTAB71 Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
19
Past 30 Days:
81
All Time:
733
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
This guide will explain how to replace the camera in this tablet. If there is any confusion about removing the battery, see the battery replacement guide.
    1. Uniden UTAB71 Camera Replacement, Camera: step 1, image 1 of 2 Uniden UTAB71 Camera Replacement, Camera: step 1, image 2 of 2
      • Use a plastic pry tool to separate the two halves of the tablet.
      • Make sure to be gentle with the pry tool and work your way around the edges of the tablet slowly.
      • Make sure the tablet is powered off before prying open.
      • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
      Ask FixBot
    2. Uniden UTAB71 Camera Replacement: step 2, image 1 of 2 Uniden UTAB71 Camera Replacement: step 2, image 2 of 2
      • Use a credit card to lift the battery off the back of the tablet.
      • Do not put any pressure on the motherboard or any other internal components.
      • The battery is glued onto the back of the tablet so make sure to apply as much pressure as needed
      Ask FixBot
    3. Uniden UTAB71 Camera Replacement: step 3, image 1 of 1
      • Undo the clips off the power ribbon connecting the camera to the motherboard using the blue pry tool.
      Ask FixBot
    4. Uniden UTAB71 Camera Replacement: step 4, image 1 of 3 Uniden UTAB71 Camera Replacement: step 4, image 2 of 3 Uniden UTAB71 Camera Replacement: step 4, image 3 of 3
      • Use the pry tool to remove the yellow tape from the power ribbon connected to the camera.
      • Place the plastic pry tool under the camera component and lift it off the tablet.
      Ask FixBot
Author
with
Ryan Jewell
443 Reputation
4 Guides authored
UMass Dartmouth, Team 5-4, Martin Fall 2016 Member of UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 81
All Time: 733
