Up to 20% off select tools
Uniden UTAB71 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
18
Past 30 Days:
79
All Time:
946
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 - 20 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
Replacing the battery on this tablet is a fairly simple process. This guide will explain the process step-by-step.
    1. Uniden UTAB71 Battery Replacement, Battery: step 1, image 1 of 2 Uniden UTAB71 Battery Replacement, Battery: step 1, image 2 of 2
      • Use a plastic opening tool to undo the clips that attach the two halves of the tablet.
      • Be gentle with the pry tool and work your way around the edges of the tablet slowly.
      • Make sure the tablet is powered off before prying open.
      • There are two power ribbons connecting the screen to the back of the tablet. Make sure not to put too much stress on them.
      Ask FixBot
    2. Uniden UTAB71 Battery Replacement: step 2, image 1 of 1
      • Lift off the tape that holds the speaker wires to the battery
      • Leave the tape off to the side
      Ask FixBot
    3. Uniden UTAB71 Battery Replacement: step 3, image 1 of 1
      • Use a soldering tool to disconnect the two wires (red and black) that connect the battery to the motherboard
      • Note the placement of each colored wire in the motherboard
      • If you have no experience in soldering, please follow this guide
      Ask FixBot
    4. Uniden UTAB71 Battery Replacement: step 4, image 1 of 2 Uniden UTAB71 Battery Replacement: step 4, image 2 of 2
      Tool used on this step:
      iOpener
      $14.95
      Buy
      • Use a credit card to lift the battery off the back of the tablet
      • Do not put any pressure on the motherboard or any other internal components.
      • The battery attached to the back panel with adhesive. You may need to use a heated iOpener to loosen the adhesive and remove the battery.
      Ask FixBot
Author
with
Ryan Jewell
443 Reputation
4 Guides authored
UMass Dartmouth, Team 5-4, Martin Fall 2016 Member of UMass Dartmouth, Team 5-4, Martin Fall 2016
UMASSD-MARTIN-F16S5G4
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 79
All Time: 946
