Up to 20% off select tools
Uniden TCX905 Button Keypad Cleaning Guide
Views: 1.6K
View statistics:
Past 24 Hours:
5
Past 7 Days:
17
Past 30 Days:
93
All Time:
1,581
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Easy
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
If problems occur with the button keypad, this guide will show the user how to thoroughly clean them.
    1. Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: step 1, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Cover: step 1, image 2 of 2
      • Starting from the top of the cover, slide down and away from the phone with your thumb
      • Lift battery cover off of batter and place it to the side
      Ask FixBot
    1. Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: step 2, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Battery Pack: step 2, image 2 of 2
      • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
      • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
      • Place battery pack to the side
      Ask FixBot
    1. Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: step 3, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Back Shell: step 3, image 2 of 2
      • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
      Ask FixBot
    2. Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 4, image 3 of 3
      • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
      Ask FixBot
    3. Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 5, image 3 of 3
      • Ensure that wired connection between circuit board and back shell is not strained
      • Fold the back shell underneath the front shell and circuit board
      Ask FixBot
    1. Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: step 6, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide, Circuit Board: step 6, image 2 of 2
      • Carefully remove the middle two 7mm screws, the outer top 9mm screws, and the top middle 7 mm screw that hold the logic board to the front shell of the phone casing using the Phillips #1 screwdriver
      Ask FixBot
    2. Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide: step 7, image 3 of 3
      • Using index finger and thumb, carefully remove the circuit board from the front shell of phone
      Ask FixBot
    1. Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 1 of 3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 2 of 3 Uniden TCX905 Button Keypad Cleaning Guide, Button Keypad: step 8, image 3 of 3
      • Remove the white plastic sheet covering the button pad with your fingers
      • Gently remove the silicon button pad
      Ask FixBot
    2. Uniden TCX905 Button Keypad Cleaning Guide: step 9, image 1 of 2 Uniden TCX905 Button Keypad Cleaning Guide: step 9, image 2 of 2
      • Wet one end of the cotton swab with water and clean button pad as needed
      • Repeat process with multiple cotton swabs if needed
      • Dry the button pad with a clean, soft rag before replacing
      Ask FixBot
Author
with
Gary Pence
807 Reputation
8 Guides authored
Clemson, Team 1-1, Benson Spring 2014 Member of Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 17
Past 30 Days: 93
All Time: 1,581
