Uniden TCX905 Back Speaker Replacement
  1. Uniden TCX905 Back Speaker Replacement, Battery Cover: step 1, image 1 of 2 Uniden TCX905 Back Speaker Replacement, Battery Cover: step 1, image 2 of 2
    • Starting from the top of the cover, slide down and away from the phone with your thumb
    • Lift battery cover off of batter and place it to the side
    Ask FixBot
  2. Uniden TCX905 Back Speaker Replacement, Battery Pack: step 2, image 1 of 2 Uniden TCX905 Back Speaker Replacement, Battery Pack: step 2, image 2 of 2
    • Once battery cover is removed, place your thumb and index fingers on the the wires near the receptacle
    • Gently pull straight up on the wires until a click is heard which signifies the battery is completely disconnected
    • Place battery pack to the side
    Ask FixBot
  3. Uniden TCX905 Back Speaker Replacement, Back Shell: step 3, image 1 of 2 Uniden TCX905 Back Speaker Replacement, Back Shell: step 3, image 2 of 2
    • Remove the two 11mm screws inside the battery storage compartment using Phillips #1 screwdriver (located near the very bottom of the phone)
    Ask FixBot
  4. Uniden TCX905 Back Speaker Replacement: step 4, image 1 of 3 Uniden TCX905 Back Speaker Replacement: step 4, image 2 of 3 Uniden TCX905 Back Speaker Replacement: step 4, image 3 of 3
    • Gently open phone casing along the seam at the bottom of the phone using index and middle fingers of both hands
    Ask FixBot
  5. Uniden TCX905 Back Speaker Replacement: step 5, image 1 of 3 Uniden TCX905 Back Speaker Replacement: step 5, image 2 of 3 Uniden TCX905 Back Speaker Replacement: step 5, image 3 of 3
    • Ensure that wired connection between circuit board and back shell is not strained
    • Fold the back shell underneath the front shell and circuit board
    Ask FixBot
  6. Uniden TCX905 Back Speaker Replacement, Back Speaker: step 6, image 1 of 2 Uniden TCX905 Back Speaker Replacement, Back Speaker: step 6, image 2 of 2
    • Lay the back shell with the inside facing up
    • To remove the speaker guard, first remove the 7mm screw from inside the back shell
    Ask FixBot
  7. Uniden TCX905 Back Speaker Replacement: step 7, image 1 of 3 Uniden TCX905 Back Speaker Replacement: step 7, image 2 of 3 Uniden TCX905 Back Speaker Replacement: step 7, image 3 of 3
    • To access the speaker, flip the back shell over and use a plastic opening tool to pop open the black cover
    • Gently push the speaker guard out of place with your thumb
    • Carefully slide the speaker out from its setting and place speaker guard aside
    Ask FixBot
  8. Uniden TCX905 Back Speaker Replacement: step 8, image 1 of 2 Uniden TCX905 Back Speaker Replacement: step 8, image 2 of 2
    • With speaker exposed, remove the speaker by cutting the red and black wires near their contact location
    Ask FixBot
Gary Pence
807 Reputation
8 Guides authored
Clemson, Team 1-1, Benson Spring 2014 Member of Clemson, Team 1-1, Benson Spring 2014
CLEM-BENSON-S14S1G1
3 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 26
All Time: 719
