Uniden Guardian G955 Touchscreen Replacement
    1. Uniden Guardian G955 Touchscreen Replacement, Touchscreen: step 1, image 1 of 1
      • Use a J1 Phillips screwdriver to remove the four 6.1 mm screws at the back of the monitor.
      Ask FixBot
    2. Uniden Guardian G955 Touchscreen Replacement: step 2, image 1 of 1
      • Use metal spudger or an opening tool to pry open the device.
      Ask FixBot
    3. Uniden Guardian G955 Touchscreen Replacement: step 3, image 1 of 2 Uniden Guardian G955 Touchscreen Replacement: step 3, image 2 of 2
      • In both pictures, disconnect the zero insertion force (ZIF) connector from the motherboard using your fingernail by sliding up on the male end of the connector to loosen it.
      Ask FixBot
    4. Uniden Guardian G955 Touchscreen Replacement: step 4, image 1 of 1
      • Use a J1 Phillips screwdriver to remove the two 6.1 mm screws.
      Ask FixBot
    5. Uniden Guardian G955 Touchscreen Replacement: step 5, image 1 of 2 Uniden Guardian G955 Touchscreen Replacement: step 5, image 2 of 2
      • Apply pressure to metal casing and slide off.
      Ask FixBot
    6. Uniden Guardian G955 Touchscreen Replacement: step 6, image 1 of 2 Uniden Guardian G955 Touchscreen Replacement: step 6, image 2 of 2
      • Push touchscreen through black case.
      Ask FixBot
Pauline Lara
301 Reputation
2 Guides authored
USF Tampa, Team 1-1, Nance Fall 2016 Member of USF Tampa, Team 1-1, Nance Fall 2016
USFT-NANCE-F16S1G1
3 Members
48 Guides authored
4 Guide Comments
would the steps be the same for the g755 screen?
CLAY WILLIAMS - Reply Share
Would steps be the same for the G755?
Where do u buy the screen?
Ian - Reply Share
I need a battery and the screen: model G- 955
Sn : Ho6305109
Henry - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 24
All Time: 1,520
