Introduction
Before you attempt to replace the battery you should first check the troubleshooting guide to ensure you need a battery replacement.
To remove the battery cover, push in and downwards towards yourself on the cover. There is a notch on the back that you can use to get a better grip if necessary.
Push the wires back into the housing to allow the battery to fit under the battery cover.
Put the cover back on. Listen for a click, which will indicate the cover is placed correctly.
