Up to 20% off select tools
Uniden D1688 Base Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
13
Past 30 Days:
89
All Time:
814
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
  • Spudger
    4.9
  • Phillips #1 Screwdriver
    5
Introduction
Go to step 1 ↓
In this guide, you will learn how to dissemble the the base of Uniden D1688. You will learn how to use the spudger to open the case.
    1. Uniden D1688 Base Replacement, Uniden D1688 Base Replacement: step 1, image 1 of 1
      • Unplug the phone from the base by detaching the RJ-11 plug.
      • Flip the base upside down, and use the Phillips #01 screwdriver to unscrew the seven screws (Head size: 5.11mm, length: 8.6mm) on the underside of the base.
      Ask FixBot
    2. Uniden D1688 Base Replacement: step 2, image 1 of 2 Uniden D1688 Base Replacement: step 2, image 2 of 2
      • Using the spudger, separate the top shell of the base from the bottom shell from the base.
      • Use care when separating the base so the ribbon cable between the top shell circuit board and the bottom shell circuit board is not damaged!
      • Lift the top shell off the bottom, and you have successfully opened the phone base.
      Ask FixBot
Author
with
justin
419 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 13
Past 30 Days: 89
All Time: 814
