Uniden D1483-3BK Handset Keypad Replacement
    1. Uniden D1483-3BK Handset Keypad Replacement, Battery: step 1, image 1 of 1
      • Set the phone with dial keys facing downward.
      Ask FixBot
    2. Uniden D1483-3BK Handset Keypad Replacement: step 2, image 1 of 2 Uniden D1483-3BK Handset Keypad Replacement: step 2, image 2 of 2
      • Slide the battery cover toward the bottom of the phone.
      • Lift and remove the back cover from the phone.
      Ask FixBot
    3. Uniden D1483-3BK Handset Keypad Replacement: step 3, image 1 of 1
      • Remove the battery from its compartment.
      • Pinch the end of cord where the battery is attached to the phone and pull up gently.
      Ask FixBot
    1. Uniden D1483-3BK Handset Keypad Replacement, Handset Case: step 4, image 1 of 2 Uniden D1483-3BK Handset Keypad Replacement, Handset Case: step 4, image 2 of 2
      • Remove the two 9mm Phillips #1 screws in the battery compartment.
      Ask FixBot
    2. Uniden D1483-3BK Handset Keypad Replacement: step 5, image 1 of 3 Uniden D1483-3BK Handset Keypad Replacement: step 5, image 2 of 3 Uniden D1483-3BK Handset Keypad Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to carefully separate the two halves of the case.
      • Slowly work around the entire case to fully separate the halves before pulling them apart.
      • Wires inside the case hold the two halves together, tearing these wires will lead to a need for additional repair.
      Ask FixBot
    3. Uniden D1483-3BK Handset Keypad Replacement: step 6, image 1 of 2 Uniden D1483-3BK Handset Keypad Replacement: step 6, image 2 of 2
      • Carefully remove the 9mm Phillips #1 screw from the top corner of the circuit board.
      Ask FixBot
    4. Uniden D1483-3BK Handset Keypad Replacement: step 7, image 1 of 2 Uniden D1483-3BK Handset Keypad Replacement: step 7, image 2 of 2
      • Carefully grasp either side of the circuit board and lift it straight out of the front half of the case.
      • Set the board in the lower half of the case.
      Ask FixBot
    1. Uniden D1483-3BK Handset Keypad Replacement, Handset Keypad: step 8, image 1 of 1
      • Remove the rubber keypad from the front half of the handset case.
      • The keypad comes in two separate pieces.
      Ask FixBot
6 other people completed this guide.
Arbitrary Name
1,083 Reputation
4 Guides authored
Penn State, Team 1-8, Kaschak Winter 2015 Member of Penn State, Team 1-8, Kaschak Winter 2015
PSU-KASCHAK-W15S1G8
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 27
All Time: 451
