Unbranded UB-15MS10 Screen Replacement
    1. Unbranded UB-15MS10 Screen Replacement, Screen: step 1, image 1 of 1
      • Use an opening tool to pry off the lid of the memory card compartment.
      Ask FixBot
    2. Unbranded UB-15MS10 Screen Replacement: step 2, image 1 of 1
      • Use a Phillips #00 Screwdriver to unscrew the two 1.2mm screws within the compartment. This allows the device to be opened.
      Ask FixBot
    3. Unbranded UB-15MS10 Screen Replacement: step 3, image 1 of 2 Unbranded UB-15MS10 Screen Replacement: step 3, image 2 of 2
      • Insert opening tools to partially pry open the cover.
      Ask FixBot
    4. Unbranded UB-15MS10 Screen Replacement: step 4, image 1 of 1
      • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
      Ask FixBot
    5. Unbranded UB-15MS10 Screen Replacement: step 5, image 1 of 1
      • Remove the tape that is holding the battery in place.
      Ask FixBot
    6. Unbranded UB-15MS10 Screen Replacement: step 6, image 1 of 1
      • Unscrew the five 1.2mm screws that connect the circuit board to the device.
      Ask FixBot
    7. Unbranded UB-15MS10 Screen Replacement: step 7, image 1 of 1
      • There are three silver tabs around the internal components that connect it to the frame with screws. Unscrew these screws to remove the internal components.
      Ask FixBot
    8. Unbranded UB-15MS10 Screen Replacement: step 8, image 1 of 1
      • Carefully lift the internal components from the screen and place them into a replacement screen.
      Ask FixBot
To reassemble your device, follow instructions 1-7 in reverse order.
2 other people completed this guide.
Evan Peterson
338 Reputation
2 Guides authored
1 Guide Comment
All the instruction are fine to follow except the last one, step 8. What tool to use to lift the internal components from the screen frame or where to start to lift without damage to the internal components?
Alfred H. Schaefer - Reply Share
Past 24 Hours: 3
Past 7 Days: 26
Past 30 Days: 104
All Time: 2,564
