Unbranded UB-15MS10 Motherboard Replacement
Views: 1.9K
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
106
All Time:
1,904
Comments: 2
1 comment on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Easy
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Unbranded UB-15MS10 Motherboard Replacement, Motherboard: step 1, image 1 of 3 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: step 1, image 2 of 3 Unbranded UB-15MS10 Motherboard Replacement, Motherboard: step 1, image 3 of 3
      • Use an opening tool to pry off the memory card door located on the back of the tablet.
      Ask FixBot
    2. Unbranded UB-15MS10 Motherboard Replacement: step 2, image 1 of 1
      • Remove the two 1.2mm screws found under the memory card door.
      Ask FixBot
    3. Unbranded UB-15MS10 Motherboard Replacement: step 3, image 1 of 3 Unbranded UB-15MS10 Motherboard Replacement: step 3, image 2 of 3 Unbranded UB-15MS10 Motherboard Replacement: step 3, image 3 of 3
      • Pry around the outside carefully using the black spudger to get in.
      • Putting many opening tools around the edge helps keep it from sealing shut again.
      Ask FixBot
    4. Unbranded UB-15MS10 Motherboard Replacement: step 4, image 1 of 2 Unbranded UB-15MS10 Motherboard Replacement: step 4, image 2 of 2
      • Remove the ribbon cable by using the black spudger to release the tab and carefully pull out the ribbon cable.
      Ask FixBot
    5. Unbranded UB-15MS10 Motherboard Replacement: step 5, image 1 of 3 Unbranded UB-15MS10 Motherboard Replacement: step 5, image 2 of 3 Unbranded UB-15MS10 Motherboard Replacement: step 5, image 3 of 3
      • Peel up the grey tape so that you can get to the board and untape the ribbon cable that was removed from the motherboard in the previous step.
      Ask FixBot
    6. Unbranded UB-15MS10 Motherboard Replacement: step 6, image 1 of 2 Unbranded UB-15MS10 Motherboard Replacement: step 6, image 2 of 2
      • Remove the five 1.2mm screws from the board.
      Ask FixBot
    7. Unbranded UB-15MS10 Motherboard Replacement: step 7, image 1 of 1
      • Use an opening tool to remove the board from the case.
      Ask FixBot
    8. Unbranded UB-15MS10 Motherboard Replacement: step 8, image 1 of 2 Unbranded UB-15MS10 Motherboard Replacement: step 8, image 2 of 2
      • Detach the three ribbon cables using a spudger
      • Desolder the black, white, and red wires.
      Ask FixBot
    9. Unbranded UB-15MS10 Motherboard Replacement: step 9, image 1 of 1
      • Unscrew the two 1.2mm screws from the speaker.
      • These screws are wired to the motherboard.
      Ask FixBot
    10. Unbranded UB-15MS10 Motherboard Replacement: step 10, image 1 of 1
      • Unscrew the two 1.2mm screws of the other speaker.
      • These screws are also wired to the motherboard.
      Ask FixBot
    11. Unbranded UB-15MS10 Motherboard Replacement: step 11, image 1 of 1
      • Remove the old motherboard from the tablet.
      • Take the new motherboard and solder the black wire of the board to the black wire of the battery.
      • Do the same for the white and red wires.
      Ask FixBot
To reassemble your device, follow steps 1-10 in reverse order.
Matthew Sylvia
290 Reputation
2 Guides authored
1 Guide Comment
Please where can I get the motherboard or charging IC of UB15MS10
Ayo Olowo - Reply Share
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 106
All Time: 1,904
