Unbranded UB-15MS10 Battery Replacement
    1. Unbranded UB-15MS10 Battery Replacement, Battery: step 1, image 1 of 1
      • Use an opening tool to pry off the lid of the memory card compartment.
      Ask FixBot
    2. Unbranded UB-15MS10 Battery Replacement: step 2, image 1 of 1
      • Remove the two 1.2 mm screws within the compartment using a Phillips #00 screwdriver.
      Ask FixBot
    3. Unbranded UB-15MS10 Battery Replacement: step 3, image 1 of 2 Unbranded UB-15MS10 Battery Replacement: step 3, image 2 of 2
      • Insert opening tools to partially pry open the cover.
      Ask FixBot
    4. Unbranded UB-15MS10 Battery Replacement: step 4, image 1 of 1
      • With the cover being partially held open, slide a spudger around the seam to pry off the cover.
      Ask FixBot
    5. Unbranded UB-15MS10 Battery Replacement: step 5, image 1 of 1
      • Remove the tape that is holding the battery in place.
      Ask FixBot
    6. Unbranded UB-15MS10 Battery Replacement: step 6, image 1 of 1
      • Cut the wires connecting the battery to the device using a pair of wire cutters.
      Ask FixBot
    7. Unbranded UB-15MS10 Battery Replacement: step 7, image 1 of 1
      • Carefully remove the battery, making sure that all wires are disconnected.
      Ask FixBot
    8. Unbranded UB-15MS10 Battery Replacement: step 8, image 1 of 1
      • Splice the new battery with the red, white, and black wires connected to the motherboard.
      Ask FixBot
To reassemble your device, follow directions 1-7 in reverse order.
4 other people completed this guide.
Evan Peterson
338 Reputation
2 Guides authored
1 Guide Comment
No wonder this tablet was not a big success for Best Buy. Cutting the battery cables has to be an engineering nightmare. It makes no sense to solder something like a battery to the motherboard knowing fully well it has to be replaced in the near future. The engineer that designed this hopefully is in the unemployment line.
Milton Carroll - Reply Share
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 119
All Time: 3,083
